And to think, I previously used an emoticon for a reason..... It's not about how I feel.....If I am wrong, then tell me how else you'd do this..... JB Weld? ![]() Make it right the first time ![]()
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 05-24-2012 at 09:37 PM. |
#22
How long after your purchase did you notice the problem? Did the JB Weld work at first or was it a problem right away? I have no idea of the potential for success, but I'd look into whether you could somehow prove that the guy knew about the problem and misrepresented what he was selling. If he purposely sold away his problem, who knows, maybe you could get some money from him in a small claims court or something like that. There are a lot of assumptions in there but a cracked block materially changes the value of what you purchased. |
#23
Was this a one owner boat? If so, they knew of the crack. It not, then it would be harder to prove that the seller knew of the issue,....but I'd have to believe they did.
Clearly the boat was neglected, based upon the pics - usually a case of "buyer beware". However if you got the boat for a really good deal, and if you plan on keeping it and enjoying it for years to come, even if you paid too much - it's a awesome boat and deserves to be repaired correctly. Do that, and you will recoup way more in terms of enjoyment and the boat will hold it's value surprisingly well. If you are bummed out, just go price a brand new mastercraft....you will feel better real quick!
Jack ----------------------------------------- 1989 ProStar 190 Power Slot Somewhere between SML and LKG Last edited by d2jp; 05-25-2012 at 11:27 PM. |
#24
Lt1 blocks come in two varieties 4 bolt main (Corvette) or 2 bolt (camaro/firebird)
Both will work equally well with the 2 bolt being cheaper and easier to find
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
#25
From an old boat I re-did, here is JB in action.... first pic is JB in the red outline and JB leak in the blue outline. Second pic is further damage on the head where JB wouldn't work. The entire head was cracked all the way across. The Magnetic Particle test is shown in black area and the actual crack is shown in the blue area. That is green particle powder held in the crack from the MT (in between the black diamonds). My previous point is illustrated; where there is damage in one place, often times it extends to further areas of damage. This head cracked all the way across. JB sprang a leak after only 2 hours of engine operation, and these pics were the result. Both heads were replaced, the block surface was visual tested, MTed and PTed prior to putting on new heads. .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 05-25-2012 at 08:29 PM. |
#26
As I mentioned previously, I just purchased my first tube of JB Weld to fill some holes in my trick skis. My dremel tool cut through it like butter and it was pretty easy to file and sand it smooth. That being said, I would only use JB weld on an engine block in an emergency case to get me from point A to B. Then I would pull the engine and have it repaired or replaced.
“You realize your odds of winning the lottery are the same as being mauled by a polar bear and a regular bear in the same day”….E-Trade Baby. |
#27
That looks like your heads, not your block. Just yank the heads off and have redone.
#28
How much should I expect to spend on the block and where would be the best place to look? Can you buy the block alone or should I get the whole short block? Thanks
#30
Some people rescue animals. I rescue neglected MasteCrafts. It breaks my heart to see these awesome boats in such sad shape. I feel I got a good price, I felt I could replace the interior and engine and still make money if I sold it. |
| Tags |
| 350, block, cracked, engine, lt1 |
