  #141
Old 03-05-2014, 12:38 AM
CrazyJohnny's Avatar
CrazyJohnny CrazyJohnny is offline
Boat: Mastercraft, X10, 2006,5.7
Originally Posted by wtrjock View Post
I thought about that too. Black anodized and they would disappear into the panel. On my boat they look ok because of the aluminum insert
Sent from my Samsung Note 3 using Tapatalk Pro
Just ordered some for my X10; are you using the stock hardware? Any tips on the install?
Old 03-05-2014, 01:32 AM
wtrjock's Avatar
wtrjock wtrjock is offline
Boat: Mastercraft, X10, 2005, MCX
Send a message via MSN to wtrjock Send a message via Yahoo to wtrjock
Use your stock hardware. The front is a torx and the back is a nylock 7/16". Remove the seat. I removed the small upholstery trim next to the Black panel to gain more access. 2 people would really help because the center nut is way on there. Don't pry up the bottom because you risk breaking the trim in the middle. Go in from the right side and reach to the middle.
Plan to scrap your arm with the fiberglass...it is just part of the job.
2005 Canadian Blue Flake X10
Old 03-07-2014, 09:45 PM
wtrjock's Avatar
I tried to install my second set of spacers on my buddies 2003 x9. The front spacer works. The 2 rear ones are too long. Very similar to a previous picture I've seen. Could you cut me 2 that are are a couple millimeters shorter?
Also, the round doesn't work on these year panels. Can you cut the bottoms off and make it into a D shape?
Old 03-08-2014, 08:48 AM
MI_Corey's Avatar
MI_Corey MI_Corey is offline
Boat: 2008 X1
Can do that no problem wtrjock. PM sent.
Old 03-09-2014, 09:00 PM
MI_Corey's Avatar
Boat: 2008 X1
Showed some to my local dealer this weekend and they took 24 so I will be running another batch soon.
Old 03-13-2014, 09:49 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I received mine and installed them. They look much better, although I have some rust staining from the old washers and they don't get covered up. I guess I need to find something that will remove the stains. Either way, they look much better. Thanks!
Old 04-15-2014, 01:15 AM
Came out great! Thanks. FYI to anyone doing this, it is a two person job to get the front washer in, very tight space.
Old 04-29-2014, 08:45 PM
Fletchx7's Avatar
Fletchx7 Fletchx7 is offline
Boat: 2002 Mastercraft X7
MI_Corey, I could use a set if you still have some. PM Sent
Thanks!
2002 X7 (Current)
1988 Tristar 190 Open Bow (Old)
Old 05-10-2014, 04:49 PM
ORSkier ORSkier is offline
Boat: 2004 x7 Predator
MI_Corey,
I just sent you a PM as well. Would love to get my hands on a set of these grommets for my 2004 X7. Talk soon. Thanks!
Old 05-22-2014, 06:32 PM
MI_Corey's Avatar
Boat: 2008 X1
So, a little update. I've had a few people run into an issue with some models that the position closest to the dash sits on an angle so these don't work in that spot. Now that I've got my boat, (which happens to have this issue), I'm working on coming up with a solution. It's going to be a pain to machine, but I believe this will work.
