Old 05-22-2012, 01:07 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
Here is the fitting with the small orifice:
2006 Maristar 200 SS
Old 05-22-2012, 02:11 PM
SpryBeast SpryBeast is offline
Boat: 2015 X30 6.0
My dealer also suggested that I install the fitting with the smaller hole for this same problem. The one they got me was part number #650680, orifice .0018. To be honest I can't speak to it's effectiveness as it's been sitting on my workbench for 2 years.
Old 05-22-2012, 03:09 PM
I would contact dennis at UFP...
http://www.ufpnet.com/ContactUs/tabid/60/Default.aspx
dennis is the TN location.
Old 05-22-2012, 04:11 PM
rgardjr1's Avatar
Do you know if you have the UFP actuator on your trailer? The reverse lockout solenoid on the Reliable actuator has a different thread type than the UFP actuator. I tried to source a fitting to convert it, but I haven't had any luck. I wish I had some one at my local Mastercraft dealership that could answer questions for me, but I've struck out so far.
Old 05-22-2012, 04:34 PM
Boat: 2015 X30 6.0
Pretty sure mine is Reliable.
Old 05-22-2012, 04:48 PM
kgrove kgrove is offline
Boat: 2011 X-25
I still don't have a picture, but my dealer tells me I have a Reliable actuator - apparently no longer used on Mastercraft. He replaced the master cylinder and the shock already and also did something about the size of some kind of orifice (all these repairs are doing something to the size of one of my orifices as well).
I'm told Reliable is out of business and parts are unavailable so my only choice is to switch to UFP (Unique Functional Products).
Old 05-22-2012, 05:02 PM
rgardjr1's Avatar
I'm in the same boat. My Reliable master cylinder went T.U. and I'm replacing it with a UFP. I wasn't going to use the orifice because the threads didn't work, but now it sounds like I need to. I'm pretty sure the newer Mastercraft trailers use the UFP actuators so there should be an orifice part available through Mastercraft. Keeping my fingers crossed.
Old 05-22-2012, 05:09 PM
where was that fitting....coming out of the master cylinder? connected to a small hose feeding back to the master cylinder reservoir?
Old 05-22-2012, 06:29 PM
rgardjr1's Avatar
The fitting was connected to the reverse lockout solenoid one one side and the flexible brake line that runs to the brakes on the other.
Old 05-22-2012, 06:46 PM
That would not cause the chattering. When I spoke with the folks at UFP the only things that cause that noise is a bad shock absorber, air in the lines, or a bad master cylinder...in my case the shock was bad.
