Old 05-18-2012, 11:49 PM
BrianT's Avatar
BrianT BrianT is offline
Boat: 2011 X2 5.7 Ilmor
Water in the battery tray
I have water in the battery tray in my X7. I lifted the battery out to feel to see if there is a drain anywhere, nothing..... So my question is am I missing something and why on a low nose boat would they not put a drain in the betters area? Now I have to try to scoop out a bunch of water every time I take on some water over the nose?
Old 05-19-2012, 07:18 AM
amcmac's Avatar
amcmac amcmac is offline
Boat: X2
I'm right there with you. My X7 is the same way. I am looking for a solution to this problem. I'd like to add a drain into the bilge if possible.
Old 05-19-2012, 07:52 AM
MattsCraft's Avatar
Battery Box? This is what I have for my 2 batteries.
Old 05-19-2012, 08:42 AM
amcmac's Avatar
Boat: X2
On the X7/197, there a built in battery box, sort of. It is a hole in the floor with a cover. That battery box pictured would definitely protect the battery if water got down in the hole. I'm interested to know if anyone has done anything to drain the water out of the battery hole.
Old 05-19-2012, 10:23 AM
holdenh2o holdenh2o is offline
Boat: 2005 Prostar 197 Tournament Team #8/100 w/ Zero Flex Mini 2011 Black GMC Yukon XL 2011 Silver Chevy Silverado Z71 Canyon Lake, Lake Austin and Lak
Look forward to solutions...
2005 Mastercraft Prostar 197 Tournament Team #8 of 100
Old 05-19-2012, 10:29 AM
JR8778 JR8778 is offline
Boat: 2002 Mastercraft X-7
if the battery should spill acid it would go down the drain as well. No acid in my bilge.
Old 05-19-2012, 11:04 AM
BrianT's Avatar
I guess I get a "turkey baster" and suck the water out every time......
Old 05-19-2012, 11:12 AM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
There is no.drain into the bulge due to the fact the want acid contained. The water beta in the from condensation mostly on the battery. Same happens on my 205v. I just check it every now and then. Buddy drilled a hole in his to the bulge, but I am more on the sealed box in case of an acid leak.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 04-13-2013, 12:52 PM
DBR's Avatar
DBR DBR is offline
Boat: MC, Sportstar OB, 1999
Do you know the location of where he drilled a drain hole? I can't tell where it may drain to the bilge in my 1999 X-Star
Old 04-13-2013, 01:04 PM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
I would not drill any holes, I think a few have done this thinking any liquid would drain into the bilge area, and found out it didn't. I had the same problem with my 190, and have found that a battery cover larger than the size of the storage box works just fine. You could even use a tupperware or some sort of plastic container upside down to cover your battery and the box below.
