Old 05-01-2012, 10:43 PM
Boat: 1987 ProStar 190
Modifying a marine stereo cover for a 1980s ProStar 190
I'm in the process of fixing up a new-to-me '87 PS 190. The boat came with a cobbled together and broker stereo cover in the very narrow dash area.
I knew I had to replace it but had a nearly impossible time finding a cover narrow enough to fit in the 2 1/2" tall spot where the stereo is located. I don't think there is an off the shelf cover that will fit without modifications.
Here is what I started with:
I thought about relocating the stereo and covering the hole with a plate, but decided to try modifying this small marine cover I found on ebay. It was about $10 shipped. Luckily, they included the dimensions in the ebay listing so I knew it would fit after some modifications.
Here is a link to the same item: http://www.ebay.com/itm/Boat-Radio-H...5a7f21&vxp=mtr
It arrived.
The first thing to do is measure the frame of the stereo. Mine was 7" x 2". They should all be relatively similar. I then covered the front with painters tape so it didn't get all scratched up while I had it face down on my workbench.
This cover was made for the old style 2-post stereos. This is where you take out your dremel and modify the back to fit. I cut out a 7" x 2" hole to accommodate the face of my stereo.
Eventually after some back-and-forth trimming I got a pretty tight fit. You have to be careful not to remove too much material as there will only be 1/4" of frame on each side when you're done.
It's not attached to the hull yet, and I'm not sure how I'm going to do that either. Some kind of adhesive? I would like to make this as waterproof as possible. Any suggestions?
[IMG][/IMG]
Old 05-02-2012, 01:32 PM
imjusthereforthefood imjusthereforthefood is offline
Boat: 87 ps 190
great work!
Old 05-02-2012, 01:56 PM
DemolitionMan's Avatar
DemolitionMan DemolitionMan is offline
Boat: 2008 Pro Star 197 TT #58 of 100
The stereo looks great!
Automatic doors make me feel like a Jedi
Old 05-02-2012, 04:26 PM
SkiDog's Avatar
SkiDog SkiDog is offline
Boat: 92 Prostar
That white dash looks even better, but nice work on the stereo too!
Old 05-02-2012, 04:31 PM
Nicely done.
Old 05-02-2012, 04:35 PM
mayo93prostar mayo93prostar is offline
Boat: 1993 Prostar 190 Blue Stars and Stripes, Powerslot
That cover looks alot better than the rough hole. I recommend to use some clear silicone caulk to fasten the cover to the dash. I assume you have the radio supported with something behind the dash. How about a pic of the whole boat?
1993 Blue Stars and Stripes Prostar Powerslot 351HO
Mastercraft: Face It - If you are not a good skier behind this boat, you are not a good skier.
Old 05-02-2012, 04:48 PM
Yeah, I think silicone is what I'll end up going with.
As far as more pictures of the boat, check out this thread:
http://www.mastercraft.com/teamtalk/...ad.php?t=46548
