thanks BMcD, Darren at the MC dealership says that the new x30 has a better wave than the x35, but it wasn't clear if this was from having rode it himself or just repeating the official MC marketing
CantRepeat - yes I read what you wrote, I have just been looking to hear more opinions, to see if anybody else had direct experience. |
#12
i went out on a x30 with stock ballast in knoxville and I have been out on the 35 several times weighted and all I can say stock the 30 is alot better and if it had extra weight i can only imagine how big it is
#14
when i say that i mean stock vs stock the 30 is better
#15
http://slayshtank.com/2011/06/mastercraftwakesurf/
Tim Gone, surfing. |
#16
Hadi,
Just driving around Lake WA I don't think the difference in maneuverability will matter. You'll get used to either quickly. The only scenario that it might create a little more discomfort is when you're docking into a tight, unfamiliar place. On the other hand, the water on Lake WA can get quite rough, and the better rough water behavior could very well make a big difference in comfort for you and your passengers. I can't speak for the specific differences between the X-35 and X-30; I don't know just how the X-30 behaves in rougher water, or how much more maneuverable it is than the X-35. What I can say is that I previously had 205V based X-2 (similar to the X-1) and now have an X-25. The X-2 may be the most maneuverable V-drive MC has made. It felt like a sports car. The X-25 handles more like a big sedan. It doesn't turn nearly as quickly so I have to be more thoughtful in tight spaces or slow speeds. But in normal driving, really no functional difference. The big difference is that the X-25 is a deep V and cuts through the rough water to the extent I don't notice it much any more, whereas the X-2 got pounded. Even just crossing over my own wake when turning around -- huge difference that my crew and I noticed and appreciated right away. It also means that on many afternoons when I wanted to take the boat out for a cruise with friends and family, or a tubing session with kids, with the X-2 I wouldn't go because it was too rough, or the risk of taking hits over the bow. No problem with the X-25 -- and I get much more family use with the X-25 than I did with the X-2 as a result. |
#17
Sorry only X30 pic I had.
#18
BMcD - I test-drove both, at least on a calm day, the maneuverability difference was pretty obvious. x30 turned much more quickly, x35 reacted a few seconds later, (and required hydraulic steering). I think this also could make it harder to pick up a surfer/boarder once they are in the water, it's slightly harder to circle around them.
I've spoken with Darren at MC and test-driven both boats, he says x30 has a better surf wake, but I'm not sure if that's from his personal experience or repeating MC's marketing. |
#19
Stock for Stock the X-30 is more maneuverable along with having a better surf wake and better beginner wakeboard wake. The 35 can have a massive surf wake, but needs a lot of weight. Mr Hazen, I believe, was running about 4000lbs of ballast on one side of the boat.
#20
and remember.. this is for a beginner. I learned to surf behind a 79 S&S, it took alot of skill to let go of the rope, so when i'm on a big wake it seems like cake now. I don't think you could go wrong with either.
the 35 is just SUCH a big boat, and the 30 is shiney and new, although with being awesome. |
| Tags |
| wakesurfing, x30, x35 |
