Old 06-03-2011, 06:20 PM
aarosurf's Avatar
aarosurf aarosurf is offline
Boat: '190
another packing box question...
I just replaced the stuffing in my packing box with new goretex "virtually dripless" packing. This morning I took the boat out for some wakeboarding, and when I checked the box it was scalding hot. Water literally vaporized when it touched it. I only hand tightened it... didn't use a wrench whatsoever. There was no dripping at all, do I just need to hand untighten it some?? Or is there another problem. I'm just worried because I followed the instructions on virtually every thread to only hand tighten the box.
Old 06-03-2011, 06:29 PM
JMann's Avatar
JMann JMann is offline
Boat: 1991 Prostar 190, Indmar 351
Send a message via Yahoo to JMann
I would guess it's to tight. I did mine and never checked again, but only went out once since. I probably should after my next run.
I would loosen a 1/4 turn and check again.
Old 06-03-2011, 06:30 PM
flipper's Avatar
flipper flipper is offline
Boat: 1991 Prostar 190, fuel injected 302
Sounds like it's way too tight.
Lots of power is good, more is better, too much is just right.
'91 prostar 190
Old 06-03-2011, 07:43 PM
aarosurf's Avatar
Boat: '190
Figured as much. Even though it's "dripless" I'm going to target a drip every 30 seconds or so and see if that works.
Old 06-04-2011, 09:11 AM
bturner2's Avatar
bturner2 bturner2 is offline
Too tight. I've found it better to have it leaking and then adjust it to minimize the flow. If it get's too hot it could score the shaft and melt the packing in which case you're back to square one, or worse.
Old 05-04-2012, 10:48 AM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
Does anyone know what "too hot" is? Some information on the web says 10-12deg F above water temp. A friend did his and was getting readings spiking about 160deg F.
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 05-04-2012, 11:46 AM
CantRepeat's Avatar
Boat: No Boat
Is this on a dripless of log-pack with gortex cord?
Either way I think that is way to hot. On my 92 with gortex cord and say 1 drop every 5 or 10 seconds it was never to hot to touch.
Tim
Old 05-04-2012, 12:26 PM
It's not dripless or gortex. Just the standard stuff you can get from West Marine.
From what I understand is that he's adjusted it out to a pretty good drip rate, but it still runs hot.
Old 05-04-2012, 12:50 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
I have mine adjusted for about one drip per second or two in gear. I don't worry about a little water in the bilge. I err on the side of keeping the drive shaft happy.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
