Old 04-25-2012, 04:34 PM
redraider08 redraider08 is offline
Boat: 2000 Mastercraft X-Star
2000 X-Star Ballast
What kind of ballast set up do you have in your 2000 X-Star or 205V? I just bought one and it only has the factory ballast. I will be wake boarding and eventually learning how to surf. Thanks!
Old 04-26-2012, 11:37 AM
sheckski's Avatar
sheckski sheckski is offline
Boat: 2000 205v ltr
We use 300 lbs in the well into the bow and 300 lbs going port to starboard just in front of the rear seat. Add additional using the stock keel line ballast or another bag right behind the bow bag. When we have tried weighting the rear lockers it gets very washed out, although maybe that could be offset by more bow ballast. We also use another bag right behind the driver when surfing. All in all our results are "ok" but not perfect. the surf wake in particular leaves something to be desired. if others have a different formula i will also be interested to see it.
Paul
2000 205V
Old 04-26-2012, 12:44 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I run a 750lb sac in each rear locker, a 300lb sac in the ski locker, and a 1000lb sac in the bow. 24mph at 75ft
2003 X2
Old 04-26-2012, 01:33 PM
Cary K.'s Avatar
Cary K. Cary K. is offline
Boat: 01 X-Star
My current setup is almost identical to JRW160's. The wake is awesome!
Old 04-26-2012, 01:49 PM
Lakeside09's Avatar
Lakeside09 Lakeside09 is offline
Boat: 2006 Mastercraft X1
750's rear lockers
300 center locker
260 walkway sac
650 bow sac
2006 Mastercraft X1
Exile Audio
Ronix Wake
Triple X WakeSurfers
Old 04-26-2012, 01:51 PM
kdr kdr is offline
Boat: 1994 Prostat 205, 275 hp
750's in the rear locker, 300 lbs in the ski locker, a sac in the bow walkway, about 200lbs of lead in the bow, 100lbs of lead under the passenger, and one of those small cube sacs to fine tune the wake as needed.
I run the 750's about 3/4 when wakeboarding. When Surfing, the surf side 750 is full, the other side empty, the bow sac and bow lead are moved to the surf side of the cabin.
__________
Kirk
1994 Prostar 205
1999 Prostar 205V
Old 04-26-2012, 07:15 PM
B-rad B-rad is offline
Boat: x-star
Ballast
I have A ballast set from my 99 x-star 4 Bags ballast switches etc. Email me I want it out of my garage.
Brad
Old 04-27-2012, 12:07 AM
swatguy's Avatar
swatguy swatguy is offline
Boat: 2000 X-star
Pretty much right on with kdr
Old 04-27-2012, 03:44 PM
swatguy's Avatar
Boat: 2000 X-star
B Rad. Pm sent
Old 05-08-2012, 01:57 PM
Thanks for all the input. I would like to keep all the ballast hidden, so i'm thinking i will go with the 750's in the rear locker (knowing that i will only fill them to full capacity when surfing) and get the bow sack for the front. I think this year i will just fill them with the portable pump and wait till the end of the summer to do all the pluming and install switches.
