OnBoard Battery Charger
I want to install a onboard charger on my 12 X-35. Does anyone have any suggestions on a make and model that would be the best fit?
Surf around hre ==> batterymart dot com
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . |
I have a Guest brand charger. http://www.defender.com/product.jsp?...16471&id=88417
Didn't buy it from the above link, but that's the one I have. Works great. Plug it in and forget it until next outing. Matt |
Do you have to disconnect the batteries or leave them hooked up and hooked together? Does your charger connect to both batteries? 12 volt 30 amp?
Anyone have a promariner prosport ? Sent from my iPhone using Tapatalk |
What happens when engine is running? Do have to disconnect each time you finish charging?
I have an Optima Blue top and large Deka AGM Deep cycle set up with a automatic switching relay per the Diesel's dual battery thread. Bullet proof setup. Batterys are going on 5 years old and performing nicely. Later, Matt |
The following link is the "Official Dual Battery Thread". Follow its guidance and you are golden. I did the dual batterys with the switching relay. Perfection! Never had to get up and flip the battery switch again! http://www.mastercraft.com/teamtalk/...Battery+Thread I also added a Bluesea Mini battery cutoff switch (quite nice, much better than Perko). Due to corrosion induced resistance in the entire electrical system, I rewired from the batts to the distributor with all Marine Grade terminals, lugs, and wire, crimped, solidered, shrink wrapped (self sealing, and milspec on the battery cables). http://genuinedealz.com/ Best place ever to get battery cable and connectors, will even pre make them for cheap, shipped quick!!! Prices are the best for the highest quality marine grade tinned copper wire and cable! I ran 2/0 AWG main battery cables and stepped up every wire I replaced at least one size bigger. Cleaned, de-oxidized, and applied Deoxit gold to every electrical connection every where. This greatly improved the voltages coming back from the dash through the ignition circuit. I'm now getting 13.5 V at the coil while running vs. 7.5 v before. Later, Matt |
