Old 04-25-2012, 08:02 PM
ZachDaddy's Avatar
ZachDaddy ZachDaddy is offline
Boat: MasterCraft, X15, 2007, MCX, Acme 5 Blade, Pair of WetSounds Rev410's, WetSounds SD6, 2 JL 12w6v2 subs in sealed box, JL HD750/1, WS402SQ
Increasing Horse Power?
How does someone really know how much HP your engine produces? The manual says that HP can vary from one powerplant to another up to 10 percent.
Is there a way to increase horsepower on the MC engines that is inexpensive?
Old 04-25-2012, 08:05 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Which boat do you have? You can easily and inexpensively bolt on horsepower to older, carbureted boats.
The way to know what you have is to have your engine dyno'd.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 04-25-2012, 08:19 PM
ZachDaddy's Avatar
2007 X15 with MCX motor and Acme 1285 prop. We are running 2200 pounds of ballast and I do not have a wake plate so the boat struggles to get on plane if we get to heavy.
We burn a ton of gas with full thottle holeshots, so I'm looking to possible solutions like an Acme 2305 prop thats 15" x 12" w/1.05 cup. The wake plate would be the quickest fix but its to expensive at 1500 plus install.
Old 04-25-2012, 08:20 PM
MC Hero
Based on anecdotal evidence, horsepower is probably close to 311 hp not considering what is lost to the exhaust tips. No idea how to increase the horsepower.
FAQ
Tyler Ski Club
Old 04-25-2012, 08:29 PM
bzettler83 bzettler83 is offline
Boat: n/a
Inexepnsive? Probably not.
I am sure you could port the throttle body, have some one re-program the computer, but short of that you are stuck. Everything else would likely cost a pretty penny.
I have learned over the years, most inexpensive upgrades make such a small difference they arent worth it.
Old 04-25-2012, 08:33 PM
93Prostar190's Avatar
The wake plate is not a bad option to help the bow rise.
Or you could shorten the rope and carry 500 less lbs.
Good luck.....
2008 Prostar 214 MCX
Old 04-25-2012, 08:35 PM
AZX9's Avatar
AZX9 AZX9 is offline
Boat: 2003 Mastercraft X9, MXC 350
Your first check should be what rpm you are running at wide open throttle. The MCX should be in the 4800 - 5200 rpm at WOT. For more pull and hole shot you would want to be on the high end. Effectively making it easier to spin the prop with a lower pitch prop. If this is in line when ballast are not loaded then you may need to drop a pitch or two to compensate for the extra load. Of course you will loose top end and your cruise speen will be screaming RPM.
Old 04-25-2012, 09:34 PM
madcityskier's Avatar
Why not throw more weight in the bow and call it a day?
Old 04-25-2012, 09:49 PM
Jeff d Jeff d is offline
Boat: None
Something's not right. I'm running 2,700 lbs in an '00 230 VRS (same hull as 1st gen X30) and with the 330 HP LTR and the stock prop it does ok. It doesn't jump on plane "Like a boss" or anything but I don't even use WOT to get there. My boat is about 250-300 lbs lighter (dry weight) but I'm hauling another 500 lbs of ballast + people weight (3-5 adults usually). You're supposed to have 20 more HP too.
So, I'd say either your engine isn't running right, you have weight distribution issues, or your prop isn't right.
Old 04-25-2012, 09:58 PM
MCOCD@13 out of 10
here you go... have at it.... http://www.youtube.com/watch?v=cgBc0o73CyM
this awesome - pricey but awesome... go to a local mechanic to have the engine checked....you need an engine guy...someone who can test the motor...I have 2 guys I can go to...but luckily don't have to.
2200 pounds plus people + 3600 dry weight no gas.....plus gear... I think you're overloaded...and under powered...my .02...
