Old 08-15-2005, 11:06 PM
dwood dwood is offline
Boat: Prostar 190
Unhappy Stalling problem - 87 ProStar 190
I've been having a problem when running aroung 2000 rpm for a while, as I come in and start to slow down the boat will stall.
I can only get it started by chocking it and then it will not idle - at all.
Very frustrating!
What does water in the gas act like?
I have been trying additives in the gas - still happened after 4 tanks.
Should I put in a new gas tank?
Any suggestions?
Old 08-16-2005, 07:33 AM
BriEOD's Avatar
BriEOD BriEOD is offline
1) When is the last time you changed your fuel filter
2) Check in the gas tank to make sure something is blocking the pickup
3) Could be your fuel pump
Old 08-16-2005, 08:04 AM
Hoff1's Avatar
Hoff1 Hoff1 is offline
Boat: MasterCraft, Maristar 210 openbow, 1990, 351W
Water in the gas tank causes intermittent power losses. Kind of like you are pulling the safety kill switch, but putting it back before it dies. It can cause stalling, but it should have cleared out after 4 tanks.
Old 08-16-2005, 08:18 AM
Boat: Prostar 190
I had the fuel filter changed about two months ago, everything checked - everything set-up properly and of course everything ran fine while the guy had it to fix the problem.
I thought everything was fine - no stalling for quite a while and then it just started again this past weekend trying to take the kids wakeboarding.
When driving at slower speeds - 20 or so, you can feel the engine chugging - not running smooth at all. At higher speeds I can't feel the same hesitation happening.
I don't know what to do??
Old 08-16-2005, 08:47 AM
BriEOD's Avatar
Before I went ripping stuff apart and paying big money I would check the gas tank pickup. You'll have to pull the back seat out and the panel out to get to the tank clamps. Make sure their isn't anything blocking that pickup.
Old 08-16-2005, 08:52 AM
Boat: Prostar 190
Thanks!
I will do that this weekend.
I appreciate the help!!
Old 08-28-2005, 08:43 PM
BradD's Avatar
BradD BradD is offline
Boat: MC Prosport 1992, 351 Windsor
Send a message via AIM to BradD
Any update? This sounds like the problem I'm having. Did you solve it?
1992 205 ProSport
Connelly F1
Old 08-29-2005, 01:42 PM
Boat: Prostar 190
NO, I haven't solved the problem yet.
I was going to pull the tank out but ran out of time.
Too much fuel in it and kids wanting to go skiing / wakeboarding, etc.
It was happening again this weekend.
After next weekend, I am going to drain the tank and remove it - I'll post what I find - hopefully something blocking the line.
