Old 01-26-2013, 06:39 PM
98Prostar205 98Prostar205 is offline
Boat: 1998 Prostar 205
Is this Normal??
So I go visit my boat today to begin doing some maintenance/upgrades on it. Now I'm knee deep in want to's/need to's. I need some input from you guys. I've got to pull my gas tank to get to the exhaust hoses where they connect to the flanges on the transom. I got everything out of the way, but I stopped the process when I saw these "brackets" attached to the gas tank. It looks like they are screwed into the tank! Is this normal? My initial assumption is that there is no way a screw should be put into a plastic gas tank.
Secondly, in my investigation of the exhaust, I noticed some cracking around the area where the rudder is mounted to the hull as well as the "brace" that is between the rudder mount and the strut mount. I can't tell if this crack is just in some kind of sealant around the base of the mount or if it is something I should be concerned about. Any of you guys seen anything like it? I got under the boat and inspected the area around the rudder and strut and everything looked fine.
FYI, this is a 98 Prostar 205.
Old 01-26-2013, 06:59 PM
h2oskifreak's Avatar
h2oskifreak h2oskifreak is offline
Boat: 1975 Mastercraft Stars & Stripes
I have had 2 MC's and had both tanks out (76 and a 94) and no, screws into a tank is something I have never seen and doesn't seem normal to me. I am surprised they don't leak. I am interested to see what others have to say.
"One foot in the grave, one foot on the pedal, I was born a rebel" Petty
Old 01-26-2013, 07:07 PM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 1996 PS 190
The screws in the tank are completely normal, nothing to worry about.
1996 ProStar 190
Still slummin' behind PP
Chippin' away @ the BLUE LOOP
Old 01-26-2013, 07:13 PM
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
On my tank they are machine screws that are diven into nuts which are molded into the tank-- hopefully that is what you will find and you can rest easy!
Old 01-26-2013, 07:14 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; Current: X-45 ZFTP5, ILMOR 6.0L
Its normal, their are screw receivers molded into the tank for mounting.
snork snork is online now
Boat: 07 xstar
It's all good, don't forget to grease the rudder
Old 01-26-2013, 09:13 PM
MCOCD@13 out of 10
^^+1 all good on the rudder.. I have a '95 - I have brackets... no this type of tank....
Old 01-26-2013, 09:29 PM
lakeoz tristar's Avatar
I noticed mine had the same cracking all around so I used the black 3-M 5200 and sealed every where I could see.. Not sure if that was the right way to go about it? It looks like it is the top layer that covers the foam layer so I figured this would be the best solution.
