Old 04-02-2012, 04:21 PM
jjdyn0mite jjdyn0mite is offline
Boat: Larson 165 1974 85hp merc
Tricks to changing belt? (1995 PS 205)
My engine was squealing this morning and I discovered the belt was loose. I tightened the alternator for tension and the sound went away, but looking at the teeth compared to a new spare I have, they are about half as wide. Does this indicate that it needs to be changed out? Also, how do you remove the belt? Even with the alternator pulley loosened all the way, the belt won't come off easily. I assume that even if I cut it off, the new one would be equally difficult to install. What tricks do I need to know?
Also, since I tightened it up and we went out for a long ride, the engine was running hotter than usual (it got up over 180 usually runs about 160). So you think the impeller could have been messed up by the belt running loose during that time?
Old 04-03-2012, 12:24 AM
Ok I got it figured out. I pried it off with a screwdriver, then to put the new one on you just get it started good on the left side and turn the engine (safety lanyard off) and when it turns clockwise the belt falls right in line. I guess most people already know that, but for mechanical newbies like me, maybe it will help someone. The new belt was very tight from the start and I really couldn't get any more tension on it at the alternator pulley, so I just tightened down that bolt. I also changed out the impellar although the old one looked fine at least it will give me peace of mind and I can save the old one for emergency.
Old 04-03-2012, 12:50 AM
AZX9's Avatar
AZX9 AZX9 is offline
Boat: 2003 Mastercraft X9, MXC 350
If your impeller looked good check down stream to the transmission cooler to see if there is some crap caught in it. Probably not an issue but it never hurts to replace the thermostat if it's older, they're cheap enough. I had an over heat situation last summer. Pulled and replaced what seamed like a perfectly fine impeller and thermostat and the problem was solved.
Old 06-05-2012, 04:13 PM
mtbiker29 mtbiker29 is offline
Boat: 95 Pro Star 205
Help...
I'm in the middle of this repair as we speak. The way I see it I have to remove the impeller from the crankshaft to make this happen?
If someone could confirm that would be great.
Thanks,
EW
Old 06-05-2012, 04:45 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Not sure what you mean by "crankshaft". If you mean the splined shaft inside the raw water pump, then yes. Squirt some dish soap in there, turn the engine over with lanyard removed, then pry it out.
Old 06-05-2012, 05:24 PM
MCOCD@13 out of 10
If that doesn't work you can get 2 paint openers to pry it out...don't pry to hard the housing is soft. I got an impeller puller cuz mine wasn't budging...now that I inspect often... the impeller comes right out all the time... a put a little lube on the spline shaft so it doesn't stick. only a little bit..petroleum based products can cause the impeller rubber to fail.
www.skidim.com has the tool. pricey but its the right tool for the job
Old 11-14-2012, 09:48 PM
sprite sprite is offline
Boat: 1999 prostar 190
this is the real way to change a belt!
http://www.youtube.com/watch?v=BQhfcdQf1QA
Old 11-15-2012, 08:07 AM
bturner2's Avatar
bturner2 bturner2 is offline
That's very cool but mostly insane. All that's missing in that video is someone saying " hold my beer, watch this".....
Old 11-15-2012, 08:39 AM
MCOCD@13 out of 10
Now you're just encouraging Kyle...
