#52
Great job on your 'new' boat, it looks really nice and sounds great!
Jack ----------------------------------------- 1989 ProStar 190 Power Slot Somewhere between SML and LKG |
#53
Anyone with an 87 or 88 Prostar knows that the dash area makes it nearly impossible to fit a replacement DIN stereo in place with any kind of waterproof cover. The area is just too thin to fit a normal waterproof cover. I tried cobbling together a new cover but it was hard to get it to stay in place and to keep the water out, plus it just looked dated and was cheaply constructed.
![]() I got caught in a storm once early in the summer, and the stereo died. After a summer without any tunes, I was fed up. One problem is that the dash area is VERY limited on this boat. Wanting to avoid anything with a place for water to enter (an external aux port or CD slot for instance), I decided to give the new Jensen MS30 a shot. It only takes up 3inches of space, and is completely waterproof. I bought it from Katerno for under $100 shipped: http://www.katerno.com/detail/s/3473.../USB---MS30RTL This unit was just released recently so there are zero reviews of it online. I must be one of the first. ![]() Besides being tiny and waterproof, it is actually a pretty robust little unit for it's size. On the back there are inputs for RCA AUX, as well as a USB input for an MP3 device. Cool!
There are line outs for your amp, but unfortunately no "remote" line to turn on the amp. To solve that problem, I bought a $12 unit from PAC that will accomplish the task of turning the AMP off when the stereo is no longer in use: PAC TR-4 Car Audio Remote Wire Turn On Wire 2 Second Delay Module ![]() The first thing to do was to sketch out where it would go: ![]() ![]() A multipurpose cutting bit on a Dremel made short work of the cut out. ![]() ![]() It looks good in it's new home. I should've taken a picture with the unit on, but it skipped my mind. It has a cool blue back light. Best of all, I can leave this thing outside in the elements without a cover and know it'll work the next day. ![]() The next thing to do is fab up a cover plate for that unsightly hole where my old stereo used to live. I am thinking that I'll powder coat a thin piece of stainless and then have someone etch the Mastercraft logo into it.
See my on-going 1987 Prostar 190 "project" thread here! |
#54
Looks good! Keep us up to date on how that jensen works out for you!
1991 PROSTAR 190 Flagship Blue POWERSLOT OJ XMP CNC 13.7x17.5 .110 4B A.K.A. One of a kind mistake 2011 Southern Owners Best In Show- 1987-2000 class Trying to keep slalom alive Need Parts or Services? Call BAWS 813-996-2297 Need a new prop to fit you needs? Call OJ PROPS 800-359-9730 |
#55
I know I dug this up from the dead, but I was wondering how you like that jensen unit?
#56
I'll be sure to update this thread in the spring when I get this thing out on the water.
#57
My MC has been wrapped for a couple of months now but I did take some parts off to play with this winter.
I took my crank pulley off, blasted it and powder coated it in my home powder coat setup. ![]() I also rebuilt my Johnson water pump. This thing was spray painted black and looked terrible. It also leaked like crazy. I got a new seal from skidim and it seems to hold water now in an unscientific sink test. I took a wire wheel to the body to clean off the old ugly paint. ![]() Then blasted & powdercoated the bracket, replaced the rubber grommet and put it back together with a stainless bolt. It's as good as new. ![]() ![]()
#58
Looks like you're doing a great job so far. Thanks for sharing your progress.
#59
I finally had to do something about the hole left behind by the old stereo. I was thinking about putting a tray or box in there, but couldn't find anything that looked like it would look good there.
![]() I decided to enlist the help of a machinist friend to carve me something out of CNC. First we cut some aluminum stock to fit over the hole. ![]() Then mocked something up in Adobe Illustrator using the HemiHead font. ![]() I have an old oven in my garage that I do hobbyist level powdercoating in, so I decided to coat it black (along with some other bolts for the boat). ![]() ![]() 25 minutes and 350 degrees later, cured gloss black. ![]() Today I brought the coated plate to my machinist buddy along with the file. The end result is pretty slick! I'll follow up with a final photo once I get it mounted. ![]() ![]()
#60
Nice work!
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
