#41
Nice work!! I've got an 88, and have been working on small things to tidy it up. I really like what you've done with the mount for the amp. The head unit in mine is bad, so when I replace it, I might add an amp and sub. I may have to follow your lead on the mounting. Just to clarify- you epoxied/glued the Trex blocks to the hull, epoxied bolts in to holes, then bolt the amp mounting plate to that?
G |
#42
atsa - nice.... nice work!
I used PL Premium to secure the Trex to the hull, based on other experience I read on various boating forums. ![]()
See my on-going 1987 Prostar 190 "project" thread here! |
#44
Any thoughts on maybe drilling/tapping in to the Trex instead? It would seem that the weight of the amp/extinguisher wouldn't put much load on the plastic, I wonder if a coarse-thread bolt would hold well? Or maybe thread in and epoxy a stud? Tho I guess you're not going to be installing/removing the mount plate often, so the bolt turning shouldn't be a problem.
G |
#45
- you would need exactly the right bolt length or risk punching into the hull - what if you over tightened and stripped the hole - Difficult to align when going to mount the board with amp attached (it's pretty heavy) With the bolt facing this way, you can get a slightly longer bolt and never worry that it might be too short, or that it will strip out in the trex. Also, it's MUCH easier to position everything if you can just hang your board on the bolts, then move your hands away to find your ratchet. Trying to fiddle with 2 heavy 4 gauge wires and 8 speaker wires while positioning the heavy board and trying to align the bolts in their holes could be very frustrating. I really think this is the way to go.
#46
Very good points- I hadn't thought about the weight part and having to support and align the amp mount while trying to thread the bolt in. I should have thought about that, given that a little while ago, I replaced a threaded hole/bolt combination on my motorcycle with a stud/nut system which made it much easier to mount things.
Good call! ![]() G |
#47
When I bought this boat in the middle of winter, there was no way to hear it run before exchanging the money.
Needless to say, when I got the boat out today and turned the key for the FIRST time, I was pretty thrilled when it came to life. Now all that is left is to get it wet! Next weekend will be the maiden voyage, I hope. A quick video here: http://www.youtube.com/watch?v=0ijRH...ature=youtu.be
#48
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#49
Cool video. Just ran mine on hose last weekend for the first time since last summer.
Great feeling.
1991 ProStar / 351W with 1:1 Velvet Drive |
