Old 03-31-2012, 05:42 PM
occva occva is offline
Boat: 1986 Mastercraft
boat and trailer length
I have a 1986 MC on a factory trailer. My garage is too short and I plan to bump it out so the boat fits and I don't have to store away from home in the winter. The boat is 2 hours away.
Can someone with a 86 or S&S with factory trailer please measure from tip of the tongue to the end of the platform. I have a couple numbers written down from last year and want to make sure I bump out far enough. I think the correct number I have in 261 1/2 inches.
Thanks...
Old 03-31-2012, 06:08 PM
liledgy liledgy is offline
Boat: 1985 mastercraft 351
I can fit my 85 on a mc trailer in my 24' long garage with 5-6" to spare. Your 86 should be the same or very close.
Old 03-31-2012, 06:17 PM
That would make your boat and trailer18'-6". Doesn't sound right.
Some idiot built my garage 20'.(not me)
Sent from my Milestone X using Tapatalk
Old 03-31-2012, 07:10 PM
Cloaked Cloaked is offline
Boat: MasterCraft
I figure 24' from tip to tail of the platform. I do not have an exact measurement from the 85 model. It's in storage.
Old 04-01-2012, 05:18 PM
No. I have 5-6" inches to spare. So it's a little less tan 24' feet.
Old 04-01-2012, 06:16 PM
-V-'s Avatar
-V- -V- is offline
Boat: 2000 MasterCraft MariStar 210 VRS
don't wanna be that guy but;
' = feet
" = inches
Old 04-01-2012, 06:25 PM
Sorry, read that as 5'-6".
I made the trip last night. Boat is 19 feet. Platform extends 15 3/4 inches out from the rear vent. Tip of the tongue is 17 3/4 inches from the tip of the bow. Total 21'-9 1/2".
Old 04-01-2012, 07:27 PM
d2jp's Avatar
d2jp d2jp is offline
Boat: ProStar 190, 1989, 351W
I just installed a set of Alloy Marine lift-off brackets so that I can remove my platform to make the garage fit roomier. (my garage is 24' deep).
After I back the boat in, I put storage casters under each wheel (using a floor jack) and while the trailer is still hooked up, I then push the trailer against the wall, unhook trailer and done.
You might try removing your platform/brackets and angling the trailer into the corner....it 'might' fit.
Jack
1989 ProStar 190 Power Slot
Somewhere between SML and LKG
Old 04-01-2012, 09:00 PM
I already thought about this approach. However it is still too large, even if I upgraded to gps speedo and removed the pitot tubes. I am bumping the rear wall out 2'-6". This will give me room on the other side for tool boxes and I can still get the wifes car in.
I still might install the removeable brackets so i can walk around the tongue when the door is closed.
Old 04-01-2012, 09:36 PM
d2jp's Avatar
The Alloy Marine brackets might require you to notch the teak swim platform to clear the transom lifting rings (mine did). I wanted the added room the lift off brackets provide, their design is pretty simple and a good solution for the compound curve of the transom.
My 'other side' has a big roll cab tool box and a '67 MGB I've had forever. My wife used to park her car in there, but I explained the MC was worth more long term!
I hope to hit the lake tomorrow - first time and really early for around these parts!
Jack
