Fuel Line replacement '97 PS190 LT1 ?
Hello All,
I searched the old threads but I didn't find much info on my specific question. I'm looking to change the fuel lines in my 1997 PS190 w/LT1. (specifically the lines between the tank and the fuel pump only.) I was wondering if anyone could help me out with sourcing replacement lines. I see skidim sells fuel line... but I'm not sure what to buy. Thanks for any input. |
I believe its 3/8" marine fuel line.
http://www.skidim.com/prodinfo.asp?number=MPI350-0386 I replaced my feed line tank to engine this winter. Fairly straight forward on my 1991, I imagine its the pretty much the same for a 1997, give or take. PS - flya750, as in a Textron "X"?
1991 ProStar / 351W with 1:1 Velvet Drive |
Thanks for the reply...
Textron X ? - not following on this? |
Did you have to remove anything to get the hose fed back to the tank? Or were you able to just feed the new hose easy peasy ? Thanks
As in "Cessna Citation X, C750", a Textron Company.
The hose is held on by a hose clamp on the hose barbed coming out of the fuel tank, routed behind the tank and along the bottom of the hull and held by 5-6 plastic hose clamps, and attached to fuel filter by a hose clamp to the brass barbed fitting on filter assembly. At least that is how it is on a 91 PS, I can't imagine the 1997 being drastically different. Mine was just 20 years old and I figured that is quite old to risk a fuel leak for $40 worth of materials, and since it is listed on skidim's website as one of their top 10 sellers, it's a best seller for a reason.
750 as if VFR750
Honda 750cc I agree about about the preventive maintenance... that is my plan.. I've seen what fuel lines look like in old motorcycles... it ain't pretty. Last edited by flya750; 03-25-2012 at 03:44 PM. |
Trying to replace the fuel lines on my '97 PS 190.
Anyway, the original lines have a factory molded connector on one end and an open worm gear clamp connector on the other end. Since all I can buy is the 3/8" fuel line it looks like I have to go with worm gear clamps on both ends of the fuel line. This should be okay since it's a low pressure fuel system. I'm just looking for confirmation that worm gear hose clamps will be suffice on both ends of the fuel lines? Last edited by flya750; 04-01-2012 at 12:12 AM. |
