Old 03-25-2012, 12:10 AM
chopp's Avatar
chopp chopp is offline
Boat: Mastercraft X2
speaker can adapters
Can you buy adapters so you can fit other brand speaker cans to the mounting points on a mastercraft tower, or do you have to use mastercraft speaker cans.
thanks
Old 03-25-2012, 04:07 AM
Boat: Boat
I know Exile sells a mount for their speakers so you can bolt them right to the 07+ towers.
Tim
Gone, surfing.
Old 03-25-2012, 04:23 AM
chopp's Avatar
thanks mate . i did a bit of a search on here and it looks like mc sell the adapters ,but they don't have them on their site , and may be expensive. will check out the exile ones
Old 03-25-2012, 10:34 AM
EarmarkMarine's Avatar
Boat: TBD
A Bullet HollowPoint 770NEO 7.7" HLCD will mount right up to the 07 & up tower pads with the existing flange and no need for an adapter. These are in really nice domestic spun aluminum pods.
Exile has an adapter that will facilitate their own speakers which includes a 6.5" surf coaxial, 6.5" HLCD and an 8" HLCD.
Wetsounds has an adapter that will facilitate their own speakers which includes an 8" surf coaxial, 8" HLCD and 10" HLCD.
Either the Exile or Wetsounds will provide a swivel mount that quick-disconnects.
There's seven speaker choices.
David
Earmark Marine
www.earmarkmarine.com
Old 01-21-2013, 06:29 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Is there a swivel mount avail for existing JL cans?
Old 01-21-2013, 07:25 PM
Boat: TBD
Not that I am aware of.
David
Old 03-17-2013, 03:35 PM
washmaster washmaster is offline
Boat: 06 x9, rtp
swivel slarification
David, just to clarify from the above posts, Exile and Wetsounds both have MC mounts that swivel and quick connect, but JL and Bullet have MC mounts that do NOT swivel or disconnect. Am I correct?
Old 03-17-2013, 04:20 PM
Boat: 06 x9, rtp
Also, Bullet says something about being able to angle the driver within the can. How is that accomplished? I can't image there'd be anything more than a few degrees tilt. Or maybe I misunderstand.
Old 03-18-2013, 08:49 AM
Boat: TBD
A Bullet HollowPoint will allow the pod angle to adjust to any angle in the context of a fixed mount. This is very helpful if the speakers are mounted to the vertical portion of the tower or you want to fan out the speakers in a horizontal array. This really doesn't apply to an '07 & up MC tower if using the existing mointing pads.
A Bullet HollowPoint allows the speaker to rotate in its own pod mounting to adjust for any tower arc so that all speaker grill patterns correspond to ground level.
David
Old 03-18-2013, 12:37 PM
gts-20's Avatar
gts-20 gts-20 is offline
Boat: 2008 Prostar 214 w/ mini tower mcx
These are the Exile adapters on an my '08 tower.
