Old 03-24-2012, 03:29 PM
-V-'s Avatar
-V- -V- is offline
Boat: 2000 MasterCraft MariStar 210 VRS
Raw Water Pump Leak
Having problems here. It started leaking as i was warming it up for the first time this year. can anyone give me suggestions on how to fix it or what is wrong? It is not a bad leak but it is noticable.
Old 03-24-2012, 03:56 PM
mark g's Avatar
mark g mark g is offline
Boat: 87 prostar 190
Looks like the seal gone replacement from skidim easy fix, check the bearing while your at it, probably worth changing while stripped down.
Old 03-24-2012, 04:56 PM
mtajpa's Avatar
mtajpa mtajpa is offline
Try looking over this post.
http://mastercraft.com/teamtalk/show...r+pump+rebuild
99 MariStar 230 Sport LTR 330
Old 03-24-2012, 04:58 PM
Table Rocker's Avatar
You can get a "long" impeller kit which comes with what you need to rebuild your pump.
http://store.inboardonline.com/iwwida.pvx?;products_no_tree?cat=2350
Old 03-24-2012, 05:36 PM
-V-'s Avatar
-V- -V- is offline
you guys are life savers, going to order the kit, and get this done. I do not need engine problems from me not doing things needed.
Old 04-04-2012, 07:16 PM
-V-'s Avatar
-V- -V- is offline
Just took off raw water pump. Getting ready to change out the seals........
Old 04-04-2012, 07:49 PM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
Good luck! Here's hoping it's a quick fix.
Old 04-04-2012, 08:47 PM
93Prostar190's Avatar
Just be careful with that little seal .. the 1st time I did that job I wrecked the seal putting it in ..... you should be fine .... and the drip will stop.
2008 Prostar 214 MCX
Old 05-14-2012, 05:43 PM
tommyadrian5 tommyadrian5 is offline
Boat: 1999 Sportstar 5.7L Vortec
Did this over we weekend. The impeller too a while to pull out, probably because i hadn't changed it in 7 or so years. It was in perfect shape surprisingly. The seal is seated pretty flush in its little pocket and i couldn't figure out how to pull it out with NN pliers. I ended up taking a long wood screw, screwing it lightly into the seal, then pulling out the screw with the seal attached to it, worked like a charm, pushed the new seal in, new impeller, new gasket and boom, no more leak whatsoever. Was so pumped i went ahead and fixed my ballast system too!
Old 10-20-2012, 11:44 PM
gweaver gweaver is offline
Boat: 1988 Prostar 190
Dragging up this old thread...
I'm going to try replacing the seal on my water pump, but I've got a question about the copper/brass washer. Where does that go? When I first opened up the pump, it was between the impeller and cover plate, but had slid around quite a bit. I'm thinking maybe it's supposed to slide down the impeller shaft, then the impeller goes over it. Can anyone confirm?
Thanks,
Greg
