Bendix not engaging
Hey guys pulled the boat out this weekend but go to crank and the starter just spins at high rpms and the engine doesn't turn over. Have never seen a starter do this. The starter was new last year in april. Could anything else cause this besides a busted flywheel? I also did manually turn the engine over about 1 turn just to see if the flywheel maybe had a few chips.
most likely bad solenoid...you can take the starter out and find out right away....take it to NAPA or other to have it bench tested.
spray that bendix drive with some lube...if that fixes it slap some marine grease on it and call it good.
Try a different battery, jump box or battery charger that has a start setting. Battery may be slighly discharged or bad cell. Test with battery load tester. Might start working with extra amps. Starter may have developed rust on the bendix, not letting it fully engage. Says in my operators manual to remove starter and lube gear and shaft as part of yearly maintenance. Just a partially educated guess without more tests and info. Good luck.
I'll pull it out tomorrow. Hopefully doesn't cost me another week in shipping etc. I'm guessing your manual didn't have you changing it on a merc. Merc's engineers must have just gotten fired from Jeep when they designed this layout. 2 hour pita to remove/reinstall 2 bolts
I feel your pain. I just got my new to me garage queen Maristar 240 delivered from 1700 miles from Denver Co. to VA Monday evening. Boat has 454/ 400 hp BBC 144 original hrs, boat looks new. The dealer installed a new Arco starter and battery requested by me day before it was picked up by Uship. They just rolled over motor and did not start it because did not want to break winterization. I tryed to start motor Wedsday and all I got was a click. Hooked up jump box and bam started right up. Charged battery and tested 100 percent. Still clicks till you hit key 3 or four times then will start without jump box. Looks like maybe bad solenoid for me. I still have to check a couple of other things and do some voltage test. Only good thing is starter is located on rear bell housing and easily accessable.
#8
When you have the starter out, reach in and feel the teeth on your flywheel. If the starter wasn't properly shimmed, it can chew up your flywheel.
#9
Thread Tools | |
Display Modes | |
