190 rear floor soft spot
Can anyone please tell me where a thread is that deals with fixing the rear center floor area right behind the motor box. I know there has to be some discussions about it. I have search and must be using the wrong key word. Trying to find out if it is easier to fill with foam and reglass or just make a new piece out of wood? It's on a 1991 190. Thank you and glad I found this site (although I don't think my wallet agrees).
The flooring is made of honeycomb aluminum. Most often, the issue is that the bolts holding the motorbox in place don't have big enough washers to spread the load of the motorbox and pull through. On my 93, I just reinforced the area where the bolts were with a piece of wood and used longer bolts and larger washers. If you have a soft spot, you could reinforce it like that, but use a piece of HDPE, like a cutting board. It is heavy, but it won't rot and is rigid enough to strengthen the floor piece.
Just a thought.
Thank you. The motor box screws are okay at this time. It's just behind there where the soft spot is. Right in front for the bench seat. All the rest of it is as hard as a rock. I do like the idea though of putting bolts all the way through for the motorbox with large washers on the under side.
I did a google site search for the forum for "honeycomb aluminum." Got some good results.
Link to Search Results
I see you mention seat.
If you use your rear seat all the time, an option is to spin the floor piece around and put the bad section under your seat. Then you have a 'new' section where it once was soft. Make sure to use big washers or better yet, a plate when you remount the hinges. Kinda rigging it, but easier cheaper and you don't have to find carpet. |
I turned mine around like East tx is saying to do and I put 2 layers of fiberglass down on the under sided to reinforce seems to be going ok so far
This place is the best. I am very glad I found it. Lot's of info and great people.
Never thought to turn it around. Not a bad idea. Thanks East TX for the search. It brought up some good ideas. |
