Narrow Garage
Anyone ever modify their trailer to fit in a narrow garage. I miss by only about 2 inches. I was wondering if there are narrow trailer rims wheels and removable fenders... probably no chance, but thought it worth asking in case.
so what did you end up buying?
I would modify the garage over the trailer.
This forum is amazing with quality people.: I did not think i'd ever own an Inboard. Now I finally have a gorgeous 94 205 I am glad I have ya'll backing me up.
That's why they call you spooky
1987 TriStar 190 Red & White Ski Yesterday, Ski Today, Ski Tomorrow |
I don't see why what you're suggesting wouldn't work if all you need to gain is 2" of clearance. You're probably going to need some different rims with more backspacing (Not necessarily any narrower). That will bring the center lines of the tires closer together. Remove fenders, modify or grind off brackets, install some narrower metal fenders from the aftermarket (You will likely need to fab up some brackets). When you shop for narrower series tires make sure they still have a sufficient load rating.
The problem I see is being that precise with your backing. If you can reduce the width by 2" will that mean that it will fit with 0" of clearance on each side? Or would it technically fit at the moment but you just need a bit of wiggle room? Once you get past the door I assume you have more clearance, right? Is this a tandem trailer or single axle? With a single axle it may be doable but with a tandem you really can't make small adjustments and if you're off by a degree or two you'll have to pull out and start over. |
Also, OEM MasterCraft fenders seem to be a hot item. So, you could likely offset the cost of your new fenders and bracket fabrication with the resale of those.
On and old boat and old garage I had a similar issue. I made a horizontal cut on the door jams and trim about 36" up from the pad. I took out the nails and replaced with a couples screws. When I wanted to take out or put the boat in the garage, I just unscrewed the lower jam section and it was enough room to slear the fender interference. The rough opening is usually 2"-4" wider than the finished opening. It was a bit of a pain but it worked and was cheap. This also depends on your garage contruction.
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif |
Nothing yet, but seems that almost all trailers are about the same width. Axles widths are pretty standard I guess. I'm ready to pull the trigger as soon as the right boat crosses my path though.
Good point!
