Old 03-12-2012, 09:09 PM
zamboniman zamboniman is offline
Boat: 1958 DIY wood ski boat, 2008 X2
Cooler Ice solutions?
Wondering what others do. Looking for ice suggestions from folks that do a LOT of boating or live on the water.
Looking at years past we use a LOT of ice. Usually have people pickup bags on the way over. Bags are getting pricey, we probably spend an average $20 on ice on any given weekend. Over a season that adds up a bit.
Every summer I say I'm going to get an ice machine and I keep my eye out for a deal here and there.
I don't think I'm at the point of paying a $G plus for a dedicated machine as well as the energy to run it. I don't need to make a ton quickly all the time like a restaurant machine. And the home units don't really store more than a bags worth anyway.
Is there a better solution? Maybe just stock up on reusable ice packs? The McGyver in me is thinking to just get a garage fridge and remove the ice maker bucket and replace with something that fills most of the freezer space.
Old 03-12-2012, 09:43 PM
Get a cheap used fridge with ice maker...not side by side but freezer on top or bottom...might be able to get for a few hundred...Take out collection bucket and install a barrier to catch ice from ice maker. For example a piece of masonite or plastic to keep ice from falling out when opening upper freezer and nothing to do with freezer on bottom. Friend did this with a $100 fridge - never ran out of ice...lol. Ice sometime spilled out of upper freezer...
http://www.youtube.com/watch?v=gYryLFfOa8k - sorry couldn't resist...
Old 03-12-2012, 09:45 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; 2012 X-45 ZFT4, ILMOR 6.0L. CURRENT 2010 X14V, ZFT3, RTP-1
Get an old deep freezer off craigslist. Then contact your local ice company and have them deliver (fill your freezer) once a month. I bet you'll get a deal and you will always have ice. You could also get one of the ice boxes you see at gas stations, those show up on craigslist from time to time. Just get it delivered and save some $$.
Old 03-12-2012, 10:17 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Garage fridge with an icemaker, fill the freezer with ice.
'06 X2 MCX
Old 03-12-2012, 11:15 PM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
If you have enough alternator capacity what about one of those 12 volt powered "ice chests"?
http://www.amazon.com/gp/product/B00...XJ9C6KHW3ZZKNM
If you're skiing/boarding most of the time (i.e. engine running) it would probably work well. If you're just chilling (pun intended) in the boat then obviously it wouldn't do you much good. You'd definitely want to wire it up to ignition switched power though if your 12 volt outlets are always on like mine.
Old 03-12-2012, 11:42 PM
What we need is a good ole, Tim Allen ala Tool Time TT designed replicate-able and solution...
Old 03-12-2012, 11:45 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
Pretty good idea on the used freezer. A side by side would work well as the ice maker is usually at the top. You could take out everything and make the entire side an ice storage bin.
Also a good idea on the deep freezer. They can be had new for under $200. I am not sure that you would get a deal on delievered, but it would be worth a call to the local guys.
Old 03-12-2012, 11:49 PM
pickup truck, case of beer, final four this month - problem solved...
Old 03-13-2012, 12:20 AM
John 3:16-18
Old 03-13-2012, 12:49 AM
seth25 seth25 is offline
Boat: 2009 X2
When we go to Lake Powell we freeze one gallon water jugs and put them in the cooler. Keeps stuff cold and lasts a long time.
