Old 03-10-2012, 06:05 PM
g-mantrix's Avatar
g-mantrix g-mantrix is offline
Boat: matrix sorrento 2006 315 mrcruiser
Tower speaker removal X2 help
Hey all, wanting to remove tower speaker so I can get to light globe. I have an 07 X2 JL speaker in MC cans w/lights std stuff. Anyway went to tackle the task today by removing the screws from the speaker surround fixes into can, not only did I shear 3 of the stainless screws, but once I had removed all screws, the speaker wouldn't come awAy from the can, even with a little prising with a screwdriver around the perimeter. Any thoughts on what I need to do would be appreciated...thanks
Old 03-10-2012, 09:07 PM
TheOneandOnly TheOneandOnly is offline
Boat: Mastercraft X2, 2008, 350
They have a rubber gasket on the backside of the speaker, as I recall when I removed mine you need to pry a little all around the speaker.
Old 03-11-2012, 04:35 PM
gotjag941's Avatar
gotjag941 gotjag941 is offline
Boat: 2008 Mastercraft X-Star
They do have a gasket of some sort on the backside all you need is a flathead screw drive and tap it on the top on the speaker between speaker and can itll come out just be gentle then remove the screws mounting the can to the tower and bam there off hope this helps
Old 03-11-2012, 07:42 PM
EarmarkMarine's Avatar
Boat: TBD
If you have to pry something then slip a very thin paint scraper blade in between the speaker and the pod. Then slip a straight blade screwdriver in between the thin scraper blade and the harder of the two surfaces. Rotate the straight blade slightly and the speaker should easily release. If not then repeat the process several times in different locations around the speaker perimeter. This technique or some other adaption will keep you from gouging the materials.
David
Earmark Marine
Earmark Marine
www.earmarkmarine.com
Old 03-17-2012, 07:41 PM
keatonwakeboarder keatonwakeboarder is offline
Boat: Mastercraft,X-2,2010,350 Indimar
i just kept hitting the can with a rubber mallet till it poped out.. how long do those bulbs in the speakers last? i have the same cans.
