Old 08-10-2005, 09:53 PM
BradD's Avatar
BradD BradD is offline
Boat: MC Prosport 1992, 351 Windsor
Send a message via AIM to BradD
1992 205-Broken Belt
The belt broke tonight, fortunately I don't think i ran very long with it broken.
The person I purchased the boat gave me an extra belt since his experience told him that breaking belts was common.
The belt he gave me is much wider than the one that was on the engine.
My question is how do you get the new belt around the crank shaft pulley?
Also, is it common for belts to break?
Oh, and one last thing, any one know the part number for the belt on the 1992 351 Windsor Standard?
Old 08-10-2005, 11:07 PM
redmike's Avatar
redmike redmike is offline
Boat: 1988 prostar 190
as belt wear, they sometimes get thinner...that may be the case here. To get new belt on crank pulley, loosen alternator , rotate towards engine to give belt slack, put belt over crank pulley, tighten belt by prying a little on alternator while tightening bolts back up.
As forthe part #, it should be on the belt if the old belt didn't disintegrate. Your local auto parts store should have a match if you bring in the old belt!
Hope this helped! Good Luck
if god had meant for man to swim he wouldn't have made MC!!!!
Old 08-11-2005, 08:16 AM
BradD's Avatar
I may be missing something here, but to get the belt over the crank pulley, it looks like i need to undo a lot of things. I didn't want to start taking too many things apart before checking with all of you, if i the bracket off that is holding the crank pulley, is alignment difficult when putting back together?
Old 08-11-2005, 09:27 AM
BradD's Avatar
I can see the part number on the broken belt and it is different from the one given to me by the previous boat owner. I'll call the MC dealer here in town.
1992 205 ProSport
Connelly F1
Old 08-11-2005, 09:44 AM
Leroy
That's too bad. Do you see a lot of pieces of belt on the floor or was it a clean break? You can also eyeball the pulleys to see if they are in line or place metal ruler across pulleys to see if any are out of line.
Old 08-11-2005, 09:47 AM
BradD's Avatar
Clean break.
How do I get the belt around the crank pulley?
1992 205 ProSport
Connelly F1
Old 08-11-2005, 10:17 AM
Leroy
Redmike answered below.
Old 08-11-2005, 10:43 AM
G-man's Avatar
G-man G-man is offline
If there is a bunch of rust on your pulleys replace them and your belts will last much longer. My belt was never replaced in 12 years but I had the chrome pulleys.
06 AWSA Approved Towboat
Old 08-11-2005, 10:44 AM
rspiecha's Avatar
rspiecha rspiecha is offline
Boat: 1994 Prostar 205/2005 Maristar 210 VRS - MCX
I broke three belts the first season on my 94. The dealer had to shim the alternator to fix the problem. I average about 1 belt every two years. I keep two belts in glove box with a tool kit at all times. If I remember correctly, I had to remove a coolant hose and the bracket/bar to the fresh water pump on the front of the crank to get the new belt on. Of course you have to loosen the adjustment bolt on the alternator. Feed the belt onto the crank, water pump, and alternator pulley and re-attach the bracket and tighten everything.
Another way belts break frequently is rust/corrosion on either the water pump pulley or crank pulley. The older pulleys are steel that is chrome plated, the newer one are all aluminum.
2005 MariStar 210VRS - MCX - ACME #845
1994 Prostar 205 TBI 350 (SOLD)
War Eagle
Old 08-11-2005, 12:53 PM
SkySkiSpokane's Avatar
SkySkiSpokane SkySkiSpokane is offline
Boat: '95 Prostar 205 LT1
Surf,
Is it an LT1?? The belts and tensioning system is completely different on LT1s than it is on the factory TBI motor? The LT1 belt is much wider, not as long and is put on with a tensioner pulley not by adjusting the alternator. It takes two minutes and you only remove the brace that attaches to the water pump to put the belt around it. Without any further details you may have the wrong belt.
Dave
'95 ProStar 205 LT1
