Old 02-17-2012, 09:12 AM
joyner1020's Avatar
joyner1020 joyner1020 is offline
Boat: 1992 prostar 205
Quick Exhaust Question
1992 Prostar 205 - 351 WINDSOR
I have 3 small trickles of water coming out of the factory mastercraft "SILENT MASTER " exhaust . It is leaking slowly but surely ..
My question and im sure this may sound stupid , but im no motor guy...
CAN I REMOVE THE OLD EXHAUST AND JUST RUN STRAIGHT EXHAUST HOSE INSTEAD OF REPLACING THE EXHAUST CANS AT 120.00 A POP ?
The boat sounds wonderful with them on and im sure it would sound alittle beefier with them off , some might not like the extra noise , but if it saves me 250.00 I think I will like the engine noise just fine ...!! I was wondering if anyone has done this and will it effect performance or just the sound . Any help would be appreciated ...
Thanks
Joe in Tennessee
Old 02-17-2012, 10:00 AM
Jeff d Jeff d is offline
Boat: None
You can repair the leaks with normal fiberglass and resin
Old 02-17-2012, 10:21 AM
carlsonwa's Avatar
carlsonwa carlsonwa is offline
Boat: 99' Sportstar
The previous owner of my 99' removed the silent masters and plumbed in PVC, it sounds pretty bada** at cruising speeds! Plenty quiet when traveling slow.
Old 02-17-2012, 03:51 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Yes, you can replace the mufflers with straight hose. At prices approaching $20/ft, dont expect to save much money, though.
You will definitely notice an increase in volume.
PCM 351w, 350hp
Old 02-17-2012, 05:36 PM
ahhudgins's Avatar
That's how I fixed a drip on one of mine. I'm at the age that I don't want a loud boat.
Old 02-17-2012, 08:27 PM
joyner1020's Avatar
Thanks for all the help guys , I was considering the PVC , but I think I will try to glass the originals first ... Tahnks for all the quick replys ...Joe
Old 02-18-2012, 03:02 AM
david_ski david_ski is offline
Boat: 1993 ProStar 351HO
I had a similar leak in my muffler. I used fiberglass and resin on exterior. I will post a picture tomorrow. I actually used a mirror and inspected the inside and found a fairly large crack at the 45deg angle on the inlet side. Unable to glass the inside, the exterior fiberglass and resin worked just fine. Much less in cost than a new replacement muffler.
Old 02-21-2012, 07:48 PM
joyner1020's Avatar
This was deff the way to go , I glassed them up and everything is good so far ..!
Old 02-21-2012, 09:12 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Agreed.
The PVC is Foxworthy material..
Old 03-14-2012, 09:31 PM
89BigBlock's Avatar
89BigBlock 89BigBlock is offline
Boat: 89 prostar 190 454
PVC?? Interesting. Anyone else other than Carlson do this? Heat is the first thing that comes to mind. Any plumbers out there that can confirm?
exhaust
