2007 Centurion Enzo 216
Only 80 hours and in EXCELLENT condition. Don't let this awesome wakeboard and surf boat pass you by. The Centurion Enzo 216 is 21.5 feet long and is touted as one of the most versatile V-drives on the planet. With multi sport capability and cutting edge styling this is a great boat for the entire family. The Enzo 216 sits on a modified V hull to give it a smooth ride in rough water and the V-drive makes seating and storage more than ample for a boat load full of people. Featuring taller sides to keep the kids dry and safe this is a great opportunity to get a used boat that looks like new.
This boat is loaded with Ballast, tower speakers, stereo system, tandem axle trailer, wakeboard tower, fiberglass swim platform, boat cover, walk through transom and much more! SPECS Passengers: 12 Dry weight: 4,300 lb. Draft: 24 in. Load capacity: 2,583 lb. Fuel capacity: 46 gal. Storage capacity: 94.5 cu. ft. Bow: and cockpit 64.5 cu. ft. Rear: 30 cu. ft. Platform: 12 sq. ft. Interior gunwale height: 36 in. Sun-pad area: 26.5 sq. ft. STANDARDS Engine: MerCruiser Mag 350 5.7L, 330 hp Prop: Acme 13 x 16 four-blade Ballast: Yes Tower: Evolution, black powder-coated Wake shaper: Adjustable wake plate Mirror: Windshield-mounted Driver’s seat: Swivel, bolster Dash: Vinyl-wrapped, tilt steering wheel Gauges: 5-inch, Faria Gas fill: Dual rear Cooler: 34.8 qt., under walk-through Cup holders: 15, stainless steel Rub rail: Stainless steel Platform: Teak Trailer: Tandem axle |
