Don't worry, he'll probably sue when something goes wrong.
Tim Gone, surfing. |
#12
no....not underboat... inside boat... the trans turns very slowly when in neutral when engine is cold... you can stop the shaft from turn "In neutral" with your thumb and fore finger...
very nice can't - ugh....
Wow, there has been some great info in this thread so far. Thanks!
gweaver, I will keep my eyes on craigslist for some towable toys. That is where I found the MC, so maybe I will have some more luck coming across something like those. Personally, I really like Napa Gold (WIX) oil filters in the cars, so thanks for providing the right Napa Gold # for me! Do you guys have the NAPA Part # for the fuel filters? A couple searches and I came up with nothing. I will look into a drill operated pump or something similar for the oil/transmission fluid changes. I may do a trans fluid change early in the season since Dexron is cheap stuff for a couple quarts. I know typically Dexron III is backwards compatible with Dexron II. I know the manual calls for the II, so I am assuming it is safe to run the Dex III? Speaking of the transmission, I will make sure to never let it turn while on land!! Since curiosity killed that cat (I haven't had the boat in gear and out of water, please don't worry), what kind of damage can be done? Is it all in the driveshaft seals, or is there a possibility of internal transmission wear? I will order an impeller before the season starts and keep it on hand. I need to tighten the impeller cover before running the motor, so I will pull it and see what it looks like. If I see any cracking or wear, it will get replaced. If it looks good, I will have a brand new spare on the boat waiting! |
#15
Look at ski-it-again.com for all your water toys, and skidim.com for parts. Putting the boat into gear while out of the water will melt the cutlass bearing in the strut which is water lubricated.
#16
There are a number of ways to pull the impeller.... try the two paint can openers first IMO. I I have a friend with an X2 he uses a pair of channel locks. I keep the impeller shaft well lubed so it comes out very easy now... On the Trans I use Castrol Dexron VI...that works well too backwards compatible...I change every season... 03geetee, cloaked, east tx skier, would probably have best advice for your tranny.
this thread talks about sticking a screwdriver in it......
STX I would call the previous owner and use what he used in the tranny if its still working great and not leaking why change it right? JTR
1983 MasterCraft Stars and Stripes Cream/Red Metal Flake "Powerslot" "The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish." -Charles Chaplin- Last edited by 03geetee; 01-25-2012 at 10:21 AM. |
#19
![]() Aint the prettiest motor out there, but for now she is doing fine so I am not cracking her open and cleaning her up until I have to. Cannot complain these ol 351s really do work, hell I found a guy with 5K hours on his original motor that is insane. You can find it on youtube if you look. JTR
1983 MasterCraft Stars and Stripes Cream/Red Metal Flake "Powerslot" "The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish." -Charles Chaplin- |
