Replace Gauges and MDC box with mechanical..
Im having some gauge issues on my '02 Maristar 230. Ive lost my fuel gauge (replaced sender, not the issue) and most recently the speedometer. What is preventing me from installing a gps speedo and using tried and true mechanical marine gauges and ditching the mdc/mastercraft stuff?
Im pretty sure the medallion gauges are no longer available, other than a full set from gls for almost $800.
2002 Maristar 230 VRS |
I'd look on ebay for single gauges.
Gone, surfing. |
No such luck..
Here's a 6 piece set in black for $200
http://www.ebay.com/itm/MASTERCRAFT-...item33685583aa Most of what you need in silver http://www.ebay.com/itm/MEDALLION-SE...item43aa1eba03 Here's a twin engine set up in white.... http://www.ebay.com/itm/MASTERCRAFT-...item53e56124e6 Here's 4 gauges for $80 http://www.ebay.com/itm/Mastercraft-...item2313fcc9a0 There actually seems to be a ton of options for you from a gauge perspective. The problem I see is that the most likely cause to your problem is going to be the MDC which is where the dollars are going to be. Switching over to actual gauges will most likely require new sending units and wiring to the dash. Not sure how that would effect the engine control or other features built into the system such as safe mode and low battery functions. |
Good question. If it's like most electronic projects I've done the answer would be no. One way to find out, try getting in contact with the source at Medallion.....
http://www.medallionis.com/Support.html Support from these vendors can sometimes be amazing, or incredibly disappointing. Let us know what you find out. |
That would be par for the course these days. Throw a Email at them and see what happens.
You might also want to check with your dealer. Mine is pretty good with working with the local folk such as myself. They've always been very helpful. Of course I been buying gear from them for the past 10 years from them so that may help my cause. |
