Old 01-10-2012, 02:43 AM
obsessed obsessed is offline
Boat: 2008 X2
Rudder Seal
Hi I have a 2008 x2 which is new to me, there is water leaking in from the rudder, I assume the seals on the rudder have been worn and need replacing. Can anyone please tell me what kind of rudder box I have and where I can get the seal from? It looks like this...
Ive searched around and read it is an ORing, in which case I guess I could get that from an autoparts store. Ive removed the rudder so far and not had time to have a proper look at where the seal is, I didnt see any ORings, which means im either wrong about the ORings or the previous owner didnt put it back together properly.
I also found this, is this the right kit?
http://www.skidim.com/prodinfo.asp?n...ST1.00-SEALKIT
Old 01-10-2012, 09:54 AM
email skidim.com...they will be able to help... mine was leaking but stopped when I lubed... looks the same as my '95
Old 01-10-2012, 05:50 PM
Boat: 2008 X2
Actually mine looks a bit different to the pic I posted.
Its like this... Seal seems to be completely worn away. Ill send it to skidim and see if they have something for me.
Old 01-11-2012, 10:55 AM
macattack's Avatar
macattack macattack is offline
Boat: 2005 MasterCraft PS197 TT, #31/100, MCX 5.7L
Obsessed: If your rudder shaft moves back & forth/side to side in the port, most likely the seal is bad; it should fit pretty snug. As mentioned, sometimes greasing the shaft will help seal it better and prevent water from leaking in. You should grease the port/shaft annually anyways.
I believe your rudder port was made by OJ Props...I would send your pic to Eric and get his opinion...extremely helpful, super customer service! I just replaced my 2005 rudder port because of seal wear; the new one works great/no more water in the bilge! mac
[email protected]
http://www.ojprops.com/contact
2005 ProStar 197TT, #31/100; Tournament PB 1.5 @ 38 off, June 2012
Old 01-11-2012, 10:59 AM
You won't see the O-rings until you remove the rudder if your model has them on the shaft, itself- they're closer to the top. Your first photo looks like the seal is at the top and will need to be removed. BTW- it doesn't look like anyone has greased it for quite a while, judging by the zerk.
Old 01-11-2012, 04:34 PM
Boat: 2008 X2
There doesnt seem to be any Orings for this kind of rudder box. I spoke to my dealer he was very helpful, he sent me some pics of the parts. The seal is at the top.
For now I have greased it well, hopefully it will slow the leak until I can get over to my dealer to buy a new seal.
This is the seal, it can be pushed into the grey top part.
Old 01-11-2012, 09:11 PM
macattack's Avatar
How much is the new seal from your dealer?
Old 01-12-2012, 03:42 AM
Boat: 2008 X2
Around $65 for the seal
I live in the middle east, we only have one dealer in the region in Dubai, I have found most things to be overpriced from them, I could order the parts from the US for cheaper (including shipping), but the dealer was very helpful so I will just get it from him in this case.
The rudder box is almost $400 compared to $170 at skidim.
Old 01-12-2012, 07:04 AM
Boat: No Boat
lol, maybe the dealer should shop at skidim!!
Good luck with your repair.
Tim
Old 05-07-2012, 04:08 PM
ttu's Avatar
ttu ttu is offline
anyone had any idea of how hard it is to remove the seal pictured above?
