Go Back   TeamTalk > General MasterCraft Topics > Tow Vehicles
Old 12-23-2011, 11:20 PM
wakescene's Avatar
wakescene wakescene is offline
Boat: 2001 Maristar 210VRS, LTR 330HP, ZeroFlex Tower, KGB Ballast, PerfectPass Wakeboard Pro,
Jkski, just be sure to check the interal clearance. Iirc stove heads are just over 1"deep. You don't want that bulb touching anything. The whelen foam seals pretty well, but add sealant where needed.
I mounted the 6head pack under my driver seat and wired it up to the acc. Vehicle has to be on to run the strobes. I'm on 8yrs with my install and not a single problem. I'm a volunteer fireman so they do gets used often.
Old 12-24-2011, 06:09 AM
jkski jkski is offline
Thanks for the reply.
I now have the bulbs in each of the light housings and sealed them in with RTV as suggested. Next I moved on to mounting my power supply which I chose to place under my rear seat (CrewCab truck). I put spacers down to keep it off the carpet to help it stay cooler as a pre-caution so next is to run the wiring to each of the bulbs and the power.
For the power, the schematic shows running to a switch then straight to the battery, which is easy but then they also show a second switch, a "momentary switch" that gets wired to another power source like an accessory and it is my understanding that when the unit is powered on, if you hit this switch it is what changes the flash pattern. So, if I were to choose not to connect this switch, does anyone know if the unit will still operate at the default flash pattern?
I am trying to stick with a very clean install and am hiding the switch(s) so the fewer the better.
Old 12-24-2011, 09:18 AM
erkoehler's Avatar
It will run without the momentary switch. I don't have one as the pattern stays the same.
www.boathouseh2o.com
Old 12-27-2011, 07:37 AM
Just wanted to say thanks again for all of the great advice, the install was successful. It took about 5 hours to get all of the wires run, secured, connections made and then put everything back together after it was tested but it looks awesome.
Thanks guys.
Old 12-27-2011, 10:28 AM
Thanks guys.
No pictures???? C'mon man!
Old 12-27-2011, 10:53 AM
Double D's Avatar
Double D Double D is offline
Thanks guys.
Need Video!!
1994 MasterCraft ProStar 205
275 HP 350 Chevy Indmar
Monster Tower & PerfectPass
Old 12-27-2011, 04:22 PM
I will work on the pics and video later this week...not sure if it is as good as Eric's but it sure does kick out some annoying light!
