Old 02-13-2012, 06:09 PM
travis351 travis351 is offline
Boat: 2016 NXT Global, Mercury Verado 175
Attention has been diverted else ware for a little bit. I'll post up when I get something done.
Old 04-10-2012, 10:55 AM
Update
Finally made some progress on my beloved "Beatercraft." Ended up sawing the old coupler off the broken shaft with a sawzall which was much easier than expected. Next, the strut bearings came out with the hack saw/screwdriver/hammer trick and the strut finally fell off, so I could re-install the frozen plastic bearings on the bench. Thanks for the tip!
Did a little gelcoat repair above the prop as well as touching up the glue around the prop log with 5200. Re-packed the rudder packing gland (first time since '03 whoops) ARE shaft went in as advertised...piece of cake. Had to trim the rubber prop log seal about 1/2" back to fit the tool in there. Replacement prop fit like a charm...engine alignment, not so much...
Old 04-10-2012, 11:00 AM
Engine mounts
New mounts are in...any sage advice? I'm hoping the mounts aren't seized up with the attaching blocks. Better hit it with PB blaster.
Old 05-11-2012, 05:23 PM
Just to save anybody else the trouble, make sure to loosen up the nut on the smaller threads on the mounts about 1/4" then tap it in so you can separate the mount from the attaching block. Had to learn this one the hard way.
driveshaft, length, shear
