Old 10-28-2011, 08:48 AM
captain planet's Avatar
captain planet captain planet is offline
Boat: 1998 Prostar 190 Anniversary, LT1
Anybody with a Mazda 3?
I have an 05 Mazda 3 hatchback. This morning my low beams don't work. I have ruled out the bulbs because, both at the same time, really? I looked on the Mazda 3 forum a little and posed the question as to the location of the relay, but really the response time on there compared to here is turtle-like.
1998 ProStar 190 30th Anniversary, Corvette LT-1, STARS AND STRIPES BABY (with a really bad bimini)!!!!!!** * Footin' anyone?
RON PAUL FOR PRESIDENT
"May future generations look back on our work and say that these were men and women who, in a momnet of great crisis, stood up to their politicians, the opinion-makers, and the establishment, and saved their country." - Ron Paul
Old 10-28-2011, 09:27 AM
JBrew JBrew is offline
Boat: 2005 MasterCraft X9
I had an 11, but I just sold it. This is from a Mazda forum:
Plenty of possibilities here:
1. Obviously, the switch could be suspected. I doubt it. Your headlights are controlled by one (or more) relays. The switch operates the relay(s). From the comments here, it sounds as if Mazda has placed separate control relays in each headlight fixture -- strange idea. If you have replaced your OE lamps with new lamps that draw significantly more current, then you could have damaged relay contacts. That doesn't sound like what is going on with your car. You may select replacement lamps that have different color outputs with the same wattage.
2. Loss of ground. I would say that this is a likely suspect. It should be easy enough to test for ground continuity with an ohmmeter, but you must first replicate the intermittent problem. If it is an intermittent ground loss, then it would probably show up as high resistance even when the light is working. There is a possibility that your headlight socket could have a good ground, but your control relay doesn't. Also a possibility that you have a corroded hot wire connection between your switch and relay coil.
3. Bad relay. This could be an intermittent fault with the relay coil or corroded contacts inside the control relay. If switching on and off fixes the problem, then that suggests bad relay contacts as the probable culprit.
4. Bad lamp is a remote possibility. As a rule, a lamp is either good or bad. However, it is possible for a lamp to have a broken filament that makes and breaks. This is a rare condition and the lamp wouldn't maintain this condition for long without failing completely. It would also tend to respond to vibration -- so you would likely see it blink while driving. Corrosion in the lamp socket is also a possibility.
Old 10-28-2011, 09:44 AM
To my knowledge the bulbs are original, but I have yet to check them. I will at lunch today. Both lights don't work on low. The high beams work fine.
Thanks for your input. From what forum does that originate?
Old 10-28-2011, 10:04 AM
http://www.mazdaforum.com/forum/mazd...problem-17454/
Old 10-28-2011, 10:09 AM
ntidsl's Avatar
ntidsl ntidsl is offline
Boat: 2005 197 TT
Got a Speed 3 but I dont know anything bout the lights...sorry...just know I love driving it!
2 at 32' off 34 mph PB July 2006
Old 10-28-2011, 10:42 AM
you also have seperate fuses for left and right low and high operation, check fuses first...
James
Old 10-28-2011, 10:44 AM
I would agree. This thing is a blast to drive. This is the first car I have ever had where I can't wait to go somewhere becasue I get to drive it.
Old 10-28-2011, 10:45 AM
I found one 40 amp fuse under the hood for the headlights. I'll look for others here in a little bit.
Old 10-28-2011, 10:57 AM
this might help
MAZDA ELECTRICAL WIRING DIAGRAM
fuse 60 and 61 control low headlamps right and left located at passenger side fuse box both 15a fuses
http://www.autoshop101.com/forms/maz-ewd.pdf
http://www.mazda3forums.com/index.php?topic=77517.0
James
Old 10-28-2011, 01:34 PM
Alright, I have good fuses, I have 14+ volts going through them relative to the switch being on and off. I have 14+ voldts at the plug going into the light and I get no continuity going through the bulbs. Now I come to find out some of these cars have xenon bulbs which means you wouldn't have any continuity through the bulb anyway, correct?
Alright, I have the halogen bulbs....which have no continuity.....which means they are dead.....BOTH of them? This is a first.
