  #71
Old 11-12-2013, 05:54 PM
At full flow my water hose will not keep up with the water demand at anything over idle. Hence, why I use the bucket. It also makes it very easy in getting the AF in the motor.
I can keep up with demand at idle, but not above idle. That's why I switched from a bucket to a tub.
Old 11-12-2013, 05:56 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
I don't have any scientific evidence, but I am inclined to believe the "Fake-a-Lake" will supply water fast enough to cool you motor when it is on the trailer running and not under any load. Even though the impeller can pump water faster, it doesn't necessarily have to. There will still be plenty of water moving through it to keep the impeller from running dry or heating up. Running from a bucket and a hose does essentially the same thing, even if the bucket seems to be dry, you are still sucking up water at a pretty good flow rate.
Old 11-12-2013, 06:02 PM
until it slips off... and a fully primed impeller works cooler as well IMO.
Old 11-12-2013, 06:07 PM
That's why I got rid of mine. Had it set and hopped into the boat carefully. Glad I had my son keeping an eye on the thing.
Old 11-12-2013, 06:12 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
I am on the same page as this. I don't use the fake-a-lake, but I direct garden hose to water pump connection. I still just don't see how running on the hose for 5 minutes is going to harm anything. Your underlined comments make perfect sense in my mind.
This said, I completely understand the ease of using a bucket or tub to get the antifreeze into the block. Brilliant idea on that end.
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 11-13-2013, 10:19 AM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
Agreed.
I'm curious...if the point is to get the engine temp up, doesn't using less water get you their more quickly, or am I missing something? There's been a time or two where my flow was low and so I saw the temp get up to 200+ pretty quickly. Isn't that the goal or is that heating up the wrong things?
Old 11-13-2013, 10:26 AM
Boat: No Boat
Originally Posted by prostar205er View Post
Agreed.
I'm not sure if you are joking or not.
Not all parts of the engine and exhaust will heat up at the same rate. With a lack of water you risk over heating parts of the engine and this includes the flex hoses and the mufflers. I'm not looking to get the temp to 200 degrees or heat up the engine unevenly.
When I'm doing my winterization I run the motor for a lot longer then 5 minutes. Getting the engine to temp probably takes 15 minutes alone. One of the things I want to accomplish is getting the oil good and warm as well.
Tim
Old 11-13-2013, 10:28 AM
Agreed.
I am very in the protect the engine at any cost or action. After seeing two motors fry head gaskets and worse I want the maximum amount of water traveling past the cylinders - The gap(surface) between cylinders is small and things get hot there very quick.
I'll call hose method adequate - but bucket or tub method best. I don't want to see the inside of my engine anytime soon. But that is just me.
When I ran the bucket method - I just could not go back. I do use hose to do a start test before I trailer anywhere tho' - just make sure she starts after sitting for a week or so.
Old 11-13-2013, 10:41 AM
Not all parts of the engine and exhaust with heat up at the same rate. With a lack of water you risk over heating parts of the engine and this includes the flex hoses and the mufflers. I'm not looking to get the temp to 200 degrees or heat up the engine unevenly.
Yes...and no. It was by accident that I saw the temp rise quickly, but it got me to wondering. So how do you know when it is to temp...or are you still going by the temp gauge but getting there at engine idle?
And are you wanting the oil warm because you are going to be changing it as well?
Old 11-13-2013, 10:52 AM
Waring up the engine can take a while in MN because the hose water isn't very warm in October. A person can take some advantage of heat soak by running the engine for five minutes, then shutting down for a couple minutes, then restarting and running for five minutes....... You do need to run at more than idle speed to get the engine warmed up and thats where the supply of water direct from the hose is not sufficient in my estimation.
