Go Back   TeamTalk > General MasterCraft Topics > Watersports > Other
Old 10-14-2011, 12:05 AM
Nick911's Avatar
Nick911 Nick911 is offline
Boat: 2013 Mastercraft X25 on order, 6.0 Ilmor, Pro Package, slammed and flaked!
Tow tube from ski pole or rear step?
So what's the deal? You tow a tube from the rear step above the platform
or from ski pole? The boat in question is an X25.
Old 10-14-2011, 06:45 AM
Boat: Boat
Do it from the tower!!
Gone, surfing.
Old 10-14-2011, 06:47 AM
Trig2275's Avatar
Trig2275 Trig2275 is offline
Boat: 2010 Mastercraft X-15
Ski pole
Old 10-14-2011, 09:04 AM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Never pull tubes from the tower....
Old 10-14-2011, 09:07 AM
Boat: Boat
Why? There is considerably more load from a wakeboarder then a free sliding tuber.
Gone, surfing.
Old 10-14-2011, 09:43 AM
Boat: Boat
As per the MC safety warnings on the tower itself.
Other recreational towables.
Gone, surfing.
Old 10-14-2011, 09:45 AM
NatesGr8's Avatar
NatesGr8 NatesGr8 is offline
Boat: 05 X-45
Tower all the way!!!!!!!
Guns don't kill people, I kill people
Old 10-14-2011, 09:49 AM
CiscoStu's Avatar
CiscoStu CiscoStu is offline
Boat: 2006 X-30, MCX
Yep - tower! It also helps keep the rope out of the water, so it doesn't always splash the riders in the face.
Old 10-14-2011, 10:59 AM
scott023's Avatar
We were told specifically be the dealer NOT to pull tubes from the tower. The manufaturers warranty will be voided should anything happen.
Also, common sense should tell you that the higher the rope is off the water, the higher potential the tube has for getting too much air.
Old 10-14-2011, 11:02 AM
scott023's Avatar
I would argue with that. The surface area of most tubes is substancially more than a wake board. Through in the fact that most tubes are more than a single rider, the weight that is being pulled is far greater as well. Combine that with speeds that are fairly close (if you're staying at or below the manufacturers recommended speed for the tubes), I'd wager that the load pulling a tube causes more stress on the tower than a wakeboarder.
