Old 10-12-2011, 08:15 PM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
Atypical? LTR belt alignment issues
I'm a little sketchy on the details but I've seen other posts where earlier LTRs had belt alignment issues. It looks like they typically slip off one notch away from the water pump on the pulley. The solution was a replacement pulley with a different offset.
I have an '00 MariStar 230 VRS w/ the LTR but my manufacture date is in '99.
I'm having the opposite issue though. The belt is riding one notch closer to the water pump. The problem is though that I have a non-factory alternator on my boat. I put on a 105 amp GM 10 SI style alternator. See here for more details:
http://www.mastercraft.com/teamtalk/...ght=alternator
As best as I can tell the alternator is aligned just fine though. I have the supplemental bracket from the recall installed but that doesn't have any affect alignment.
Here's where my memory is a bit sketchy. I think that I had alignment issues before the alternator swap. I had a lot of other minor mechanical issues to deal with at the time so I didn't think much of it. I think the belt used to come off track on the crank pulley though. I'm not 100% sure on this though and I don't remember which way it "walked" then.
I've tried putting the belt back into position but then a while later it's back in the spot as shown in the picture. The other problem is that pretty much every pulley in the system has a different shape. So, I can't just put a straight edge across the pulley faces to see where the misalignment exists.
I tried a new tensioner but that didn't help.
The simplest explanation is that it's the alternator but I'd hate to pay out the nose for a lower powered, factory alternator just to still have the same problem.
Any ideas on how to measure the alignment of the grooves on all of the pulleys?
Does anyone have experience with the replacement water pump pulleys on the LTR that could tell me which one might have about a 3/32 deeper "dish" to it?
Does anyone know about the offset of different types of alternators (i.e. Delco 10SI vs. Leece-Neville/Prestolite)? DB Electrical said they were the same relative to the mounting points when I opted for the 10SI. Can anyone confirm/deny that?
Thanks,
Jeff
Old 10-12-2011, 08:36 PM
Thanks,
Jeff
The problem has nothing to do with the alternator- it's the pulley and MC had a recall for this. The selling dealer and original buyer should have taken care of it. Call MC.
Old 10-12-2011, 08:42 PM
Boat: 2000 230 VRS
This makes me feel better but the other pics I've seen of the alignment issue addressed by the recall put the belt one notch away from the water pump. Mine is riding one notch closer to the pump. Does this make sense?
I guess I forgot the pic in my original post. Doing an OS upgrade on my computer at the moment. I will add the pic when it's done.
Thanks,
Jeff
Old 10-12-2011, 10:08 PM
Boat: 2000 230 VRS
Well, I just went and took another look at everything with a flashlight. The water pump pulley is clearly the issue. I got down there so that I could see the small gap between the it and the crank pulley from the side. The water pump pulley's grooves are offset an additional 3/32-1/8" further from the engine than the crank pulley.
I emailed my local dealer to get a price on the part which appears to be 81496005.
Old 10-13-2011, 10:47 AM
Make sure the water pump pulley is on the shaft as far as it should be (flush to the end). Also, if you estimated the difference, use a straight-edge, not your eye. You also need to check the alignment to the alternator pulley. A long straight-edge is needed for this.
Old 11-07-2011, 07:11 PM
Boat: 2000 230 VRS
Is there a dealer out there that can help me with part # 81496005? This is apparently for a belt and pulley that address the improper offset.
My local dealer didn't respond to 2 emails asking about it. I talked to a dude at BAWS and he said it had been discontinued and he couldn't find any other LTR water pump pulleys listed. He suggested that I may be able to get a regular automotive pulley from somewhere like Jegs.
I talked to another dealer and the lady talked to Indmar and found that they still offered the pulley separate from 81496005 and seemed very willing to help. My attempts to contact her again have not gotten any response though.
I checked Jegs and they offer several pulleys for the GM 5.7L but they all look significantly deeper than what's currently on my LTR. None of them list any type of offset dimension though for comparison. Is this standard?
Old 11-07-2011, 07:15 PM
If Jegs had supplied the bracket(s) and pulleys for this engine, they might have a replacement that addresses the offset but since they didn't, go to the source.
Old 11-07-2011, 07:22 PM
Boat: 2000 230 VRS
go to the source.
My 3 attempts to go to "the source" only yielded the tip to go to Jegs though.
Old 11-07-2011, 07:57 PM
From the dealer? I'm not sure they understand what is causing the offset and if not, they really need to look into this. Are they a new dealer, or do they have a high turnover rate in their service department? To be honest, if two of the pulleys are aligned well, making a spacer for the odd one would be pretty easy.
Old 12-06-2011, 09:09 PM
Boat: 2000 230 VRS
Ok, I think I was able to resolve this on the cheap.
Never heard back from my local MC dealer then another out of state dealer that I was working with fell off the map after it seemed like they were going to find what I needed.
Fortunately Chuck @ BAWS determined that 81496005 (Pulley + belt "kit" to resolve this issue) was discontinued. He checked with Indmar to see if there was a replacement part and came up with 531184 (Just the updated pulley, not the "kit") but found that it was discontinued too. He had previously looked and found no other reference to a water pump pulley for an LTR.
So, I started looking at aftermarket GM small block water pump pulleys. I was getting frustrated because most listed no specs at all (i.e. no diameter, offset or anything like that). Some listed diameter but the only spec that was commonly listed was whether it was for a "short" or "long" water pump. I was able to determine that I had a "short" water pump and it occurred to me that maybe no specs were commonly listed because it they were a commodity item that was generally the same on all GM small blocks.
So, I found one on amazon for $29.71 shipped and figured it was worth a shot:
http://www.amazon.com/Mota-Performan...3223482&sr=8-1
Just installed it and it's aligned perfectly with the crank pulley (About 3/32" offset towards the engine relative to the old one) and has a "shoulder" to prevent the belt from walking. It's a 1/2" smaller diameter than the factory pulley but from what I could tell from other users' pics the formerly available replacement pulley from Indmar was smaller in diameter as well. Unfortunately that means I have to find a suitable belt but that shouldn't be very hard.
I won't know for sure until the spring when I can run it but it looks like. Hopefully this helps someone.
