Old 10-11-2011, 04:35 PM
hairlesshacker's Avatar
hairlesshacker hairlesshacker is offline
Boat: 1990 TriStar 190
1990 351 Bogs at 2800 rpm
I have a 1990 TriStar 190 with the 351.
Recently it has started bogging down at WOT. Without a skier, it will only get up to about 3000rpm, and with a skier, it tops out at about 2800...
And when I turn a corner, the it drops down to about 2200, and sometimes won't do any more than that.. Usually it will gradually work back up to 2400-2600 if I keep it floored once I come out of the turn.
I am assuming it's a carb issue, and I've already got the rebuild kit from holley, just haven't gotten around to doing it yet.
(whenever I have spare time, I usually feel like skiing, not tinkering... then of course I get frustrated when it won't pull me right on slalom, and end up kneeboarding instead, since I don't need speed for that..)
Just wanted to ask here, is carb the most likely culprit? What else should I check? (I've checked fuel filters, but that's about it..)
Old 10-12-2011, 02:09 PM
Kevin 89MC's Avatar
Definitely sounds like a carb issue, possibly the secondaries are not opening up. Rebuild is fairly straightforward, mine went well. I would suggest you change both the fuel filter (by the fuel pump) and the water separator (in the bilge). I chased a stumble after my carb rebuild, both filters looked clean, but new ones cleaned up the issue.
Good luck,
Kevin
Old 10-13-2011, 11:33 AM
rjracin240's Avatar
rjracin240 rjracin240 is offline
Boat: Mastercraft ProStar 190 1988 351 Wheezer
Check your filter, fuel pressure, and fuel pickup in tank first before tearing into the carb. Definitely sounds like fuel flow limited.
Old 10-13-2011, 12:39 PM
j.mccreight@hotmail.com j.mccreight@hotmail.com is online now
Did you get yours straightened out?
James
Old 06-19-2012, 05:06 PM
Any More Ideas?
So over the winter I've rebuilt my carb...
And it didn't help. The engine still bogs down when pulling a skier...
And sometimes is tough to start. (sometimes starts right up..) But generally runs rough...
Here's what I've done....
rebuilt carb with holley renew kit.
replaced fuel water separator filter.
replaced fuel filter on the fuel pump.
checked fuel pickup in tank, it looks good.. checked anti-siphon valve, it looks ok..
removed and checked fuel lines between tank and filter, and filter and pump. They look good.
(changed oil, replaced spark plugs)
Changed distributor from points to EI from skidim.. Checked/adjusted timing after changing it out. (still running stock coil though)
I replaced the fuel pump, but haven't had a chance to try it out yet.. but when I had the old one off, I didn't see anything obviously wrong (it sucked when I pumped) - so I'm not optimistic that it will help anything..
I guess it's time to buy a compression guage? not sure what else to check at this point.
maybe it's just time to take it to a real mechanic...
Old 06-19-2012, 05:46 PM
pkskier's Avatar
pkskier pkskier is offline
Boat: 1987 TriStar 190
Replace the fuel lines the ethanol softens them up and the pump sucks and it collapses the line shutting down the fuel flow.
1987 TriStar 190 Red & White
Ski Yesterday, Ski Today, Ski Tomorrow
Old 06-19-2012, 07:21 PM
The hoses feel pretty firm, but it can't hurt to replace them... I'll give it a shot.
Old 06-19-2012, 10:33 PM
A compression check would certainly be in order. Are you getting any backfires through the carb when the engine bogs down?
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 06-20-2012, 12:55 AM
Yes, it did backfire once last time I had it out.
Old 06-20-2012, 01:45 AM
JaredOSU JaredOSU is offline
Boat: Mastercraft Prostar 190 351 Windsor 1:1 Borg Warner
Definitely check the compression!!! Had this same problem. Is it running hot or rough? Mine ended up being a head gasket.
