Old 10-08-2011, 11:05 AM
dboat dboat is offline
Boat: 1994 Mastercraft Maristar 225 VRS
First time adding a fat sac and pump
I got a good deal on a Fly High Tsunami pump and Pro X Series 750 lb fat sac. I'm planning on puting it in the rear next to the engine compartment. I am thinking I will manually plug in the pump to inflate/deflate each time I board. I plan on deflating it after each use.
I have a Maristar and am looking to add more weight to 1 side to surf and wake board.
I would like to know if anyone has started out this way, adding a sac without a factory ballast system.
What do you think about the set up?
Comments on your set up or my idea is greatly appreciated.
Would you go a different way? Or just scrap the whole thing?
Old 10-08-2011, 11:09 AM
Trig2275's Avatar
Trig2275 Trig2275 is offline
Boat: 2010 Mastercraft X-15
For surfing just throw it in the rear locker for whatever side you want to surf however you'll probably need a little more weight overall. For wakeboarding either lay it across the back seat or on the floor in front of the rear seats. Keep it centered. Have fun!
Old 10-08-2011, 01:37 PM
ap77's Avatar
ap77 ap77 is offline
Boat: 2015 MasterCraft X-20
Filling up manually is a great way to start. We plumbed in our fat sac after the first season of filling it manually. Ended up ordering a different fat sac for the rear compartment (perfectly sized for it) and still use the original one for the rear seat for extra weight. Note: Make sure you fill up your stock ballast first (if you have one) as the weight of the fat sac can cause damage to an empty stock ballast underneath it.
- Andrew
2015 MasterCraft X-20 (current)
2009 MasterCraft X-2 (sold)
