#2021
Sent from my iPhone using Tapatalk |
#2022
Sailboats have rudders. That boat had an outdrive. Big difference. No one should run with a baby either ![]()
1 Corinthians Chapter 13 - 11 |
#2023
Most of the time a kicker motor is seen on a sailboat or paired with an outboard motor. An outdrive is not uncommon, but you just do not see as many of them. You would usually see them on larger bodies of water or the ocean, when there may be a need to have an emergency motor to get you back to shore in case the main motor craps out on you.
#2024
My in-laws had a boat on Lake Michigan and in their marina a large number of fishing boats had fixed outboards and used the I/O outdrive for steering. I went out on several and on a large body of water it worked fine as it didn't matter to much if you meandered a bit while trolling.
#2025
You know guys, That's all great and all. But it has a tiller in which to steer it with.
It was a fixed mount which means you can't tilt it up out of the water. Like Tay said. It was welded on the transom crudely. But that still doesn't change how outboards are mounted. And they all turn. None of them, don't turn. That is just nonsense.
#2026
Maybe his main engine doesn't turn left, so when he needs to turn left he just puts the little engine in reverse. Duh. Can't believe none of you guys have figured that out yet.
#2027
2003 ProStar 197, MCX and Powerslot. RON PAUL FOR PRESIDENT[/size] "Don't steal. The government hates competition." - Ron Paul |
#2028
I'm ordering a case of props this week.
“You realize your odds of winning the lottery are the same as being mauled by a polar bear and a regular bear in the same day”….E-Trade Baby. |
#2029
Fun with girls!
2002 Blue Prostar 197, 0 Flex Tower, Perfect Pass, and The Preditor-ADHD Skier I'm pursuing my lifelong quest for the perfect, the absolutely driest martini to be found in this or any other world. And I think I may have hit upon the perfect formula ![]() |
Thread Tools | |
Display Modes | |
