Old 09-28-2011, 07:10 PM
shunra shunra is offline
Boat: 2006 X 15
Paper clip method for code reading
Hi Guys,
I've searched but for some reason I can't find out which terminals to put the paper clip into to read the engine error codes.
Anyone know the answer?
The boat is a 2002 X-Star (205V) with the TBI motor.
Old 09-28-2011, 07:51 PM
Jerseydave's Avatar
TT Hero
http://www.freeautomechanic.com/diag...blecodes5.html
^This may help.
I was njskier on here.
Old 09-28-2011, 08:09 PM
Originally Posted by shunra View Post
Hi Guys,
Check with Indmar on this- EngineNut posted that at some point, this shouldn't be done because the pin assignments were changed but I don't remember the year.
Old 09-29-2011, 12:58 PM
Boat: 2006 X 15
From the link above it looks like terminals A and B. If so, these are the same terminals I short to put the engine into "service mode" in order to set the base timing.
Does this make sense? Or it is it terminal A and B on a different connector?
Old 09-29-2011, 01:15 PM
ahhudgins's Avatar
Boat: 79 S&S. 87 Prostar Powerslot. Present 95 Maristar 200VRS
I am not a big fan of the "paper clip method" when it comes to messing with the ECM. It leaves too much room for error and you could end up shorting out the wrong pins. I ordered one of the simple code readers and modified it to leave it connected at all times. I ordered it from the same company below but it was cheaper off of their ebay site.
http://www.michiganmotorz.com/codema...der-p-513.html
Here is the link to how I installed mine.
http://www.mastercraft.com/teamtalk/...=quick+project
Old 10-06-2011, 11:49 AM
Boat: 2006 X 15
Managed to get the codes no problem. Thanks.
Anyone know how to clear them?
Old 10-06-2011, 01:31 PM
wtrskr wtrskr is offline
Boat: '94 prostar 190
to clear the codes
With the paper clip in, move the throttle to the 100% forward position then move it back to neutral and the code should clear.
Old 10-06-2011, 01:35 PM
Boat: 2006 X 15
Cool. Thanks.
