Old 09-17-2011, 02:23 PM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is online now
Boat: 1987 PROSTAR 190
PCV Valve indmar 351?
Should my PCV Valve sound like a sewing machine at idle?? Reason I am asking is I was running the boat on the fake a lake and heard a rattling. Traced it back to the pcv valve which was chattering/cycling up and down. When I removed the valve and sealed the bottom o fthe pcv with my thumb the engine idle also seemed smoother. Just wondering if it was suppossed to do that.
Old 09-17-2011, 02:30 PM
tommcat tommcat is offline
Boat: 97 Prostar 205 LT1
PCV valves that rattle are usually junk. just replace it
1997 Prostar 205, LT1 powerslot
I carry a gun because a cop is too heavy
Old 09-17-2011, 03:05 PM
That's what I figured ...thanks.
Old 09-17-2011, 06:42 PM
Good answer.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 09-17-2011, 11:36 PM
Replaced....thanks guys.
Old 09-18-2011, 01:56 PM
macattack's Avatar
macattack macattack is offline
Boat: 2005 MasterCraft PS197 TT, #31/100, MCX 5.7L
Confused Did a quick Google search and all the results were pretty much the same...if you shake the PCV valve and it rattles then it is most likely good. Normally, when it does not rattle, the ball is gummed up with oil, etc and needs to be cleaned or replaced. Either way, a cheap replacement part...
"The PCV valve is a ball check valve. It allows air/gasses to pass in one direction but not the other. With the PCV valve out, you should be able to shake it and hear the ball rattle. Also if you blow in one end you should be able to blow through it but not from the other end. IF you can not blow through it from either end OR if you can blow through it from both ends it is bad.
The springs can get weak, the ball and assembly can become gummed up with oil. You can clean them with carburetor cleaner or kerosene. Let it soak in a small container of kerosene for a while and then shake it and blow it out."
2005 ProStar 197TT, #31/100; Tournament PB 1.5 @ 38 off, June 2012
Old 09-18-2011, 09:06 PM
it is supposed to rattle if you shake it, he said it rattled while running and it should not do that. google is wrong
Old 09-18-2011, 09:23 PM
Mac thanks for the reply, tom is correct it rattles while the engine is running. I replaced it and shaking the new on next to old the old one seemed to have a much weaker spring.
Old 09-20-2011, 02:26 PM
macattack's Avatar
Great, thanks for the explanation! I missed the point of your initial PCV valve rattling while the engine was running; hence, the reason I started my initial reply with "confused." Just wanted to make sure I wasn't missing something since I'm always trying to learn something new off this forum! Glad the new one works! tks, mac
