Go Back   TeamTalk > General MasterCraft Topics > Watersports > Other
Old 09-20-2011, 09:58 AM
hragsarkissian hragsarkissian is offline
Boat: 2010 X25SS
X-25 top speed
wondering what you guys are getting at top speed. From all of the reviews I've read it seems that with the MCX the X25 should hit the low 40s.
two people on board im maxing out at 35mph. Never been able to go past that.
Old 09-20-2011, 10:06 AM
ShawnB's Avatar
ShawnB ShawnB is offline
Boat: N/A
38-39 is what I got on GPS. 5.7 Ilmor with various props.
Old 09-20-2011, 12:14 PM
wpstevenson's Avatar
wpstevenson wpstevenson is offline
Boat: 2016 x30
5.7 ilmore i can get 41 mph on GPS zero off, plate down about 30% just me in the boat. I never go more that 35 driving around anyway. ski at 34, wakeboard at 23.4 and surf at 11.0, works great for all of that.
Old 09-20-2011, 12:18 PM
jwardenjr's Avatar
jwardenjr jwardenjr is offline
Boat: 2012 X-25 6.0L "On Order"
with a 6.0 Ilmor that I test drove was hitting 43 if I remember right ? I am taking my new boat out this weekend as soon as she is broken in I will give my results ...
Old 09-20-2011, 12:26 PM
Eagle Eagle is offline
Boat: 2011 Mastercraft X-25
On my X-25 with MCX, stock ballast filled, and stock prop, I hit indicated speed of 43 mph. I did not check against the GPS, though when I've checked against the GPS at wakeboarding speeds, GPS speed exceeded indicated speed by a mile or so.
Old 09-20-2011, 01:11 PM
JTNG's Avatar
JTNG JTNG is offline
Boat: 1990 Tristar, 1998 Maristar, 2002 Maristar, 2006 X-2, 2009 X-14V 2013 X-30, 2014 X46 2018 XT22
Whats the ski wake like?
Old 09-20-2011, 01:40 PM
Boat: 2016 x30
ok to req ski around, not very good to cut hard on slalom ski, Even with the plate down going 34mph wake is still pretty big and very hard. I have had x2's and x15's, the x2 with plate skies the best, the x15 with plate is ok, the x25 not as good. The x25 does have a much better wakeboard wake than the other two boats. Surf wake is great also.
Old 09-20-2011, 01:57 PM
Boat: 2010 X25SS
Wow, that's pretty good. Like I said on a calm day itll go up to 35 but not more.
I wakeboard at 22. Still can't figure out my surf set up though. Have it on 11.6 but still not what I want it to be (factory port and KGB filled + 450lb x2 sac in port locker + 250lb on port bench + 250lb on bow bench port side).
Old 09-20-2011, 02:58 PM
Boat: 2016 x30
That should be a huge surf wake, try slowing down to 11.0 or 10.8 I have factory port filled plus 350 bag on top of tank, factory kgb filled and a 650 lbs under the port bench seat. Surf tab down on star side and attitude plate down about 30% the wake is big and long.
Old 09-21-2011, 01:32 AM
Boat: 2010 X25SS
ill try moving the weight from the bow back to the port bench. Unfortunately dont have any surf tabs just a plate.
