Old 09-11-2011, 07:13 AM
skiboyny skiboyny is offline
Boat: 1996 Prostar 190
96 Prostar 190 high idle somtimes!
Hi everyone,
I have a problem with my 96 Mastercraft Prostar 190 tbi that's been plaguing me on and off for years and now is getting more prevalent. It will at times go in to a high idle (about 1100 rpm) If I restart it may go back down to normal. It used to do this once or twice a year but just lately, It does it for a whole ski set until the boat really warms up. After it is good and warm it will run fine for the rest of the day. Anyone had a similar problem or might take a stab at directing me at troubleshooting this?
Old 09-11-2011, 10:42 AM
erkoehler's Avatar
erkoehler erkoehler is offline
Boat: 2008 MasterCraft ProStar 197
Send a message via AIM to erkoehler Send a message via MSN to erkoehler
Check the IAC.....
www.boathouseh2o.com
Old 09-11-2011, 01:14 PM
Originally Posted by erkoehler View Post
Check the IAC.....
Thanks for the reply. Had the boat out for a few sets this AM condition is much worse now. Idling high more often than not. Is there a way to check the IAC or just replace? If I unplug it while running the idle goes even higher if I leave it unplugged for a minute and plug it back in the idle would come down sometimes. It has become unmanageable at this point.
Old 09-11-2011, 01:34 PM
erkoehler's Avatar
Just replace it.
Old 09-11-2011, 07:07 PM
dietdewboy's Avatar
dietdewboy dietdewboy is offline
Boat: 1996 Pro Star 190
whats an IAC?
Old 09-11-2011, 07:09 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Idle Air Control.
Keep skiing!!!
Old 09-11-2011, 07:41 PM
Just replace it.
I did replace it a few years ago. It was better by far but still would mess up a couple of times a year. I wasn't sure that it was the problem but the boat was very usable. I'll give it a shot again. Do you know if the IAC has a high failure rate?
Old 09-11-2011, 09:18 PM
Skipper
Posts: n/a
Another cause of high idle is a vacuum leak....
Old 09-12-2011, 05:27 AM
Thanks there are only a couple of hoses and they look real solid. Is there a way to check for a leak?
Old 09-17-2011, 09:32 AM
put some new hoses in they are cheap...also make sure your firing order is correct. Indmar Engine manual troubleshoot targets, are IAC, Firing order, vaccuum, or engine module. I would also make sure everything looks very clean around the fuel and air intake.
