Old 09-11-2011, 11:33 PM
SWeaver's Avatar
SWeaver SWeaver is offline
Boat: 2010 X25, 2005 suntracker, 1993 PS205
i could use a pic from an x1/205v etc
Can somebody post a quick pic of either rear ballast pump location. I know they're on the transon behind that carpeted wall, but when i looked at my 205v, i saw a couple spots where they could be mounted, so a pic of a stock mount would be very helpful. Also, any idea how long the mounting screw is? I'd prefer not to poke out the other side. Thanks!
Old 09-13-2011, 01:50 AM
G-Star's Avatar
G-Star G-Star is offline
Boat: 2002 X-Star, LTR
I've got some I can post up tomorrow morning.
I'll subscribe so I remember
2002 X-Star w/ LTR
Old 09-13-2011, 07:54 AM
SWeaver's Avatar
Thanks so much! I knew somwbody would come through.
Old 09-13-2011, 10:03 AM
tommcat tommcat is offline
Boat: 97 Prostar 205 LT1
Just use a really long screw and cut off the extra when it comes out the other side
1997 Prostar 205, LT1 powerslot
I carry a gun because a cop is too heavy
Old 09-13-2011, 11:13 AM
G-Star's Avatar
K... here we go. Port, starboard, and everything.
You can see the thick area extends below the thru-hull bolts for the transom rings. That's where the 4 ballast pump screws go. I can't remember what length the screws were though. I guess you could pull out the transom ring and measure thickness?
2002 X-Star w/ LTR
Old 09-13-2011, 11:19 AM
G-Star's Avatar
Some detail shots of the pumps.
2002 X-Star w/ LTR
Old 09-13-2011, 02:58 PM
SWeaver's Avatar
Perfect. Thanks.
Old 09-13-2011, 03:10 PM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
G-star thanks for the pictures I too was needing some. Was there a plate or panel in front of the pumps that hide it from the storage area? or are the pumps seen just as they are?
I have a 1999 and I dont have a panel there. But hope to put my pumps there.
How do they work being up so high from the water line?
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 09-13-2011, 03:11 PM
rem_pss308's Avatar
can you take a picture of your thru hull where they get water ?
is there a valve at the thru hull?
Old 09-13-2011, 03:35 PM
My 06 x1 has a panel that screws in to those black rectangles on the floor in his picks, im assuming his does too... i would not leave them exposed wit hthe pressure of the fatsac leaning on them.
