Old 09-13-2011, 07:51 PM
Brian B's Avatar
Brian B Brian B is offline
Boat: Brand new 01 X10
What fuel pump do I need?
Here is a picture of mine!
Its a Carter and has 0591B 291 stamped on it.
Also need to know what filter to buy. Thanks for any input!
330hp Indmar 2001 X10
Old 09-13-2011, 08:34 PM
nmcjr's Avatar
nmcjr nmcjr is offline
Boat: 2002 X-Star
Should be the Delco EP356, available on Amazon. There are other brands, but Delco is made by Walbro, which I believe to be the best pump on the market. Do yourself a favor and buy the Napa 1' $15 hose listed on the other thread.
2002 X-Star
http://www.nopowerturns.com
Old 09-13-2011, 10:01 PM
Matt 230vrs Matt 230vrs is offline
Boat: 2001 230 VRS
It looks like the same pump that I have in my 230 Maristar, 330 hp. I purchased (and returned) several of the pumps listed in the fuel pump thread. Each of the pumps was physically smaller and I was not comfortable trying to use the smaller pumps. I ended up buy a new fuel cell from Mastercraft. In the end, it wasn't my fuel pump but the crank position sensor. I will be interested to see if you can locate the correct pump.
Old 09-13-2011, 10:04 PM
Brian B's Avatar
I just went through the exact same thing!
What were the symptoms that caused you to replace your fuel pump?
I dont have $500 for a new unit from Mastercraft!
Old 09-13-2011, 10:10 PM
Brian B's Avatar
The Delco one is the only one I have not had my hands on. What parts stores carry them?
Old 09-13-2011, 10:27 PM
mcxfan's Avatar
mcxfan mcxfan is offline
Boat: Mastercraft
I have an 06 X2 (mcx) and my pump failed over labor day. I bought the Airtex2065 from autozone ($73) and worked like a charm.....I cross ref'd it from the delco ep356....Not sure if its the same for you 330hp though it looks similar. It only took about 1.5hrs of labor to remove and install.
Old 09-14-2011, 08:09 AM
BallBushing's Avatar
BallBushing BallBushing is offline
Boat: 1999 Maristar 210 VRS
I had the same issue. Could not find a replacement for this Carter pump. All the others are too short, had to but the complete unit. Rambo marine $485. However, don't think it was the pump after all.
Check your transmission cooler water inlet hose for debris. Cleaned that out and the boat has never run better.
Old 09-14-2011, 01:03 PM
Brian B's Avatar
Would a clogged transmission cooler cause poor driveability and intermittent power loss?
Old 09-14-2011, 02:06 PM
Certainly caused intermittent loss of power starting at 4000, then 3000, then 2000 rpm and finally at idle. Engine would just start dropping rpms and finally dying completely. After cleaning the cooler inlet, runs better than ever.
Not sure how an overheating transmission tells the engine to shut down but that's what appeared to have happened.
BTW - I've been searching this past week for this size Carter pump and can not find a thing.
Old 09-14-2011, 02:35 PM
Brian B's Avatar
Thanks for the post! I'm going to go check the cooler lines now!
