Old 10-31-2014, 05:28 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Ball Valves/Block Drains
I wondered if anyone has installed ball valves on their engine blocks to replace the brass plugs for easier draining? I know SkiDim sells the kit with 2 block and 2 exhaust drains but I figured I could pick up a couple of 1/4 turn 1/4 npt ball valve and 2 short brass nipples for under 20 bucks. Just thinkin????
OH-IO!
Old 10-31-2014, 05:39 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
I have the pitcock valves on my block. One is froze and won't turn. The other is OK. They would work for a quick drain but it is still recommend to remove them and probe with a wire to remove any obstruction if you want to make sure your block is completely drained. A little debris clogging the valve would hold water back and you wouldn't know. The exhaust manifolds are not quite as sensitive and the quick drain valves might work OK.
Old 10-31-2014, 05:42 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
One of my drain plugs has the knock sensor on it. Not sure if your is setup the same, but I think that would be a problem if I wanted to install ball valves.
Old 10-31-2014, 06:49 PM
Footin's Avatar
I have an RTP, no knock sensor. I could install ball valves on both sides.
OH-IO!
Old 11-01-2014, 05:51 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
My old 351 ford prostar I installed petcocks on the risers and block drains....
2004 Prostar 197, ACME 843
Old 11-01-2014, 07:33 PM
Double D's Avatar
Double D Double D is offline
I have them on each water jacket. Just make sure you close them before your first time out in the spring. :/
1994 MasterCraft ProStar 205
275 HP 350 Chevy Indmar
Monster Tower & PerfectPass
Old 11-01-2014, 09:12 PM
Ben Ben is offline
Boat: '94 PS205 LT1
I just installed the ski dim kit.
Looks easy to drain for sure. So for doing a few times a year it seems to be a winner.
However, I'm disappointed the exhaust valves reduce the dia immediately. I would have debated returning, and going ball valve route, but didn't want to mess with shipping and going back to lowes.
Ski dim said you still need to remove them every three years or so to clean out the funk.
Old 11-01-2014, 10:18 PM
scottpiper27's Avatar
scottpiper27 scottpiper27 is offline
Boat: 1990 Mastercraft Prostar 190
I just bought these from ski dim. Haven't installed them yet, but Im hoping they work ok. I try to take a couple cold weather winter runs a month here in Washington. Im hoping they will cut time on the re-winterization, but I'm also concerned about chunks of debris getting stuck in them.
-Scott
Old 11-01-2014, 11:41 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
I have them on my block drains to better deal with the rules in TX these days. Home depot valves. They work well.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 11-01-2014, 11:47 PM
T-Rager T-Rager is offline
Boat: 2004 ProStar 197, MCX, Sammy Duvall
I ski all year around here in Washington and store my boat outside. I installed the SkiDim ball valves in the block and exhaust manifolds several years ago and plumbed them into a common drain hose. It takes me no more a few minutes to drop the drain hose through the hull drain hole and open the valves. Works great.
