Old 08-28-2011, 01:40 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Bilge Pump
The bilge pump in my 1991 PS sounds a bit sick. Seems to pump ok, but I am going to replace it as PM this fall.
It looks like it has two wires and is wired in series with float switch.
a) How do I go about replacing it and
b) what pump to use
TIA-
Lumbergh
Old 08-28-2011, 09:33 PM
kstumpenhorst kstumpenhorst is offline
Boat: 2000 mastercraft maristar 230 VRS 330
I got a new pump and float at walmart. $50 I think and it works great. "save money live better"
Old 08-28-2011, 09:56 PM
Ummm yeah I got one at academy, now I got a meeting.... Its simple to replace, http://www.yachtsurvey.com/bilge_pumps.htm http://www.skidim.com/products.asp?dept=1004 now where's my stapler
James
Old 06-28-2012, 12:12 AM
Appling77's Avatar
Appling77 Appling77 is offline
Boat: 1991 Prostar 190
b) what pump to use
TIA-
Lumbergh
Does yours have the manual and auto switch together on the dash? My bilge works fine on manual I'm just not sure if the auto works.
Old 06-28-2012, 12:24 AM
Lumbergh's Avatar
I replaced it long ago, bought one from Amazon.
A RULE brand, works with float switch in same compartment.
Yes, have the two way switch, on and auto.
Amazon is WAYYYY cheaper than anyone else I could find for pump. It was not exact part that was in there, but removed old and installed new. Pretty simple job all in all. The wiring is what takes the time.
Old 06-28-2012, 01:14 AM
Appling77's Avatar
But since ours have the auto option if my bilge is working good the auto should work right?
Old 06-28-2012, 07:43 AM
d2jp's Avatar
d2jp d2jp is offline
Boat: ProStar 190, 1989, 351W
Set it to 'auto' - flip up the float switch and listen for the pump to run. If I have to leave my boat in the water for several days, I sleep better at night after I've checked the float switch.
Jack
1989 ProStar 190 Power Slot
Somewhere between SML and LKG
Old 06-28-2012, 10:15 AM
MCOCD@13 out of 10
I like the sahara from atwood - you can even get it at walmart...lol
http://www.walmart.com/ip/Attwood-Sa...2-VDC/14150751
Old 06-28-2012, 11:19 AM
Lumbergh's Avatar
It works in ON or AUTO. Easy to test, ON it will run, in AUTO - lift the float switch and it will run, off when the float is down.
The hardest part of the job is unbundling the wires and figuring out what goes where, but it is pretty straightforward.
Old 06-28-2012, 05:29 PM
gotta_ski gotta_ski is offline
Boat: 1998 Prostar 190 LT-1
Anyone else rewire their bilge switch so that the auto function is always energized? My boat lives in the water and I'm not comfortable with the idea that it could be left without the bilge able to go on. Mastercraft is the only boat I've seen that has the ability to turn off the auto bilge and I'm not really sure why.
