Old 08-28-2011, 04:14 PM
quallsdw quallsdw is offline
Boat: 2002 X-Star
Everything working great! Charged up both batteries, and now just running on battery 1 only. Voltage staying at 13 at idle, and 14 when running. Thanks for all the help everyone.
Old 08-28-2011, 06:11 PM
G-Star's Avatar
G-Star G-Star is offline
Boat: 2002 X-Star, LTR
Awesome! Great to hear you got it fixed.
2002 X-Star w/ LTR
Old 09-06-2011, 12:11 PM
Willski's Avatar
Willski Willski is offline
Boat: 2008 x2
Hmmm. I wonder if I have something similar. I had alarm going off and gauges not working at all. Then, yesterday, I ran the boat and the voltage dropped under 10. Got a voltage warning. Then voltage came back up, then back down. Switches wouldn't even work. Funny thing is that the boat starts and runs fine, just alarms all of the time.
Old 09-06-2011, 12:16 PM
Boat: 2002 X-Star
willski, that does sound pretty similar to mine. My switches never stopped working though... it sounds like maybe your electrical sending unit may be bad? Maybe the alternator? My only issue turned out to be the voltage... and the new alternator has cured that. Good luck!
Old 09-06-2011, 01:50 PM
Willski's Avatar
Boat: 2008 x2
I may have to pull the alternator and have it checked. I didn't have a meter with me on the boat, so I couldn't really tell what the voltage was.
Old 10-10-2011, 09:54 AM
Willski's Avatar
Boat: 2008 x2
UPDATE!!!
I took the boat out Saturday with a meter to do more troubleshooting. Started fine. Have over 14 volts out of the alternator. Just started down the lake and it alarmed again. Pulled up the seat to check the battery, and found a loose battery cable. The one that goes over to the shutoff switch. Tightened it down, and no more issues!!
Best kind of fix. No money, just a little grief! Just thought I would post to remind others to check the simple things first!!
Old 04-11-2012, 03:29 PM
Frazby010's Avatar
Frazby010 Frazby010 is offline
Boat: 2002 Mastercraft X-Star, LTR 330hp
@Willski
I have been having the same issues with my boat. Do you have a picture of your battery and all the wires connected to it? I'm not sure I have mine hooked up correctly.... :/
Old 04-12-2012, 09:21 AM
NatesGr8 NatesGr8 is offline
Boat: 05 X-45
Fire your mechanic, he should have found the problem.
Old 04-12-2012, 09:24 AM
Boat: 05 X-45
Originally Posted by Frazby010 View Post
@Willski
Loose and/or dirty (corroded) connections are one of the main causes to electrical issues. Whats your batter setup? I'm assuming 2 batteries with a switch?
alarm, alternator, oil pressure
