Old 07-31-2005, 08:31 PM
NatesGr8 NatesGr8 is offline
Boat: 05 X-45
Amp Installation
I just finished installing an amp for my tower speakers. Ran 4 gauge from battery up for the power. And 4 gauge from a grounding terminal down the center to one of the alternator bracket bolts. Just curious what you other guys with amps have done to ground your system.
Nate
Old 07-31-2005, 09:01 PM
peason's Avatar
peason peason is offline
Boat: MC, 209, 2002, 310 HP
I grounded it right to the battery. I think this is what a lot of others have done too.
Search the stereo install threads.
The harness I bought from my dealer was all set up to ground to the battery.
Old 07-31-2005, 09:14 PM
BriEOD's Avatar
BriEOD BriEOD is offline
Grounded it to the battery.
Old 07-31-2005, 10:44 PM
SteveO's Avatar
SteveO SteveO is offline
Boat: 2017 NXT 22
I too am grounded to the battery.
Prior Toys
2015 Red Flake and White NXT20
2007 Blue and White X2 Switch
2002 White and Yellow 209
Old 07-31-2005, 11:15 PM
redmike's Avatar
redmike redmike is offline
Boat: 1988 prostar 190
ground to battery, and make sure you ran the ground away from your rca cables unless you like motor noise....
if god had meant for man to swim he wouldn't have made MC!!!!
Old 08-01-2005, 01:08 PM
Boat: 05 X-45
so all the way back to the battery huh. i'll leave it as i have it grounded now. if there are any problems i will go to the battery. thanks for the input. and dont worry about my engine noise, i have some nicely shielded cables.
nate
Old 08-01-2005, 04:03 PM
jake's Avatar
jake jake is offline
Boat: 93' Prostar 190
Send a message via Yahoo to jake
Mine is grounded to the engine block. Same place the primary battery ground connects. Figure that's the same thing as running the ground all the way back to the battery, since my ground wire basically connects to the primary ground, which is connected to the battery.
Old 08-03-2005, 11:34 AM
OhioProstar OhioProstar is offline
Boat: 1995 PS190
Send a message via AIM to OhioProstar
Jake is right. No need to go to the battery if you can get a clean ground at the engine bracket.
