Old 08-20-2011, 11:46 AM
Monteluna Monteluna is offline
Boat: MasterCraft ProStar 205 - 1994
Help: Head unit turns off when...
I turn the volume up past half-way, and/or when I turn on the blower, bilge pump, honk the horn. Can anyone give me some suggestions on what is going on here? The boat - a 1994 PS205 is new to me, and the head unit is an Alpine iDA-X100M.
Old 08-20-2011, 10:43 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Sounds like you don't have enough voltage to the radio with the accessories operating. Start checking for frayed or corrosion on the wires to your radio and the accessories.
/spôrk/
Old 08-21-2011, 12:50 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Just run a new + wire thru a relay from the old + wire (not enough cpacity on the old boats for power through the ign switch) and run a new ground.
Same problem on my '96 when I put in a better higher powered head unit.
'06 X2 MCX
Old 08-21-2011, 03:12 PM
mtajpa's Avatar
mtajpa mtajpa is offline
Had the same issue with my Alpine and ended up putting in a second battery with blue seas acr isolater and dedicated run to stereo from second battery. I guess I went a little over board but new an amp addition was soon to come.
99 MariStar 230 Sport LTR 330
Old 08-22-2011, 10:55 AM
I'm thinking I'll do this too. It wouldn't be a waste for me because I plan on adding a sub at some point anyway.
Old 08-22-2011, 11:21 AM
Bert's Avatar
Bert Bert is offline
Boat: Prostar 190 and X2
I have an alpine unit that does this. It is not wired through the ignition switch but wired to one of factory supplied + leads that is live all trhe time. Does it with the engine running or off. Any more than half volume and it shuts off. Running the blower etc. does not affect it.
Old 08-22-2011, 07:12 PM
mtajpa's Avatar
Bert, If you put a voltmeter at the stereo and start to turn up the volume you will see the voltage drop to 10.5 volts that is were the Alpine units will shut down. The main positive wire from the breaker to the ign. switch is to small to handle the power required by these head units. You need to run a larger wire from the battery to your head unit(or increase the size of the wire from the breaker to ign. switch). That should solve the problem. You can try connecting a #8 or larger wire from the battery to the head unit just to see if this is your issue. If it solves the problem then make it permanent. Just be sure to fuse the wire at the battery end. Or if you want it to work off the ign. switch you can mount a relay under the dash that is activated by the ign. switch to connect the source from the battery to the head unit. More than one way to skin this cat.
Old 08-22-2011, 07:28 PM
Bert's Avatar
Thanks, I will give it a try.
Old 08-22-2011, 07:31 PM
mtajpa's Avatar
Also wouldn't hurt to run an additional ground wire.
Old 08-22-2011, 07:47 PM
Bert's Avatar
I have a # 6 + and - that I have run up to the front from battery that I was using to power an amp before so I will use those to try it. I can see the voltage drop with out the engine running but thought it would have been ok with egine on. Never had this issue till I installed the Alpine so it fits your diagnosis.
